Originally Posted by
goonturbo
I had problems with a couple of signams that were smoking. First one was a sticking egr valve but that was also accompanied with a lack of power, Other one was a split intercooler hose, as well as knackered oil pressure seals in the turbo was pumping out plenty smoke. Is the smoke you see black or blue? One other thing is have the engine management checked, ask the garage to check it through either generic obd or generic obd can, get them to check for pending codes, pending codes are codes where the ecu sees a fault but the fault is not bad enough to warrant putting the light on. Hope this helps you. Cheers Dave
