Results 1 to 10 of 14
Thread: Smoking
    Question Smoking
    All
    I've got the CR1 Tuning Box fitted to my Cdti 150 and have done for over 14 months now - No problems at, great in fact. Anyway, decided yesterday to empty the tank and fill up to the rim with BP Ultimate go go juice. (Always had mixed fuel in the past). Anyway, I would agree with many on the site that the car certainly enjoys the ulimate fuel much much better the normal supermarket stuff. But to my point....booted the car this morning to see what the pick up was like with the new fuel and yes it went like stink, but seemed to be smoking like hell out the back, left the car behind in a plum of black smoke and kept pumping it out under load....is this right???
    Cheers all
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Yes.
    The tune box is causing fuelling / timing changes from the normal calibration tables. What you see is the effect of this fuelling / timing change. More carbon make during the combustion process. But more power.
    Unless it is smoking heavily all the time, it isn't really an issue. Only environmental / pollution.
    Unfortunately, 'tune it' boxes usually compromise emissions in favour of power and sometimes fuel economy.
    Regular Member VectraV6CDTi's Avatar
    Wilts
    On my 3.0 V6 facelift I've fitted a CRD2 and it hasnt smoked once, I think this is mainly due to the fact it probably has a particulate filter (DPF). Although I dont think this is a good thing as is could be masking potential problems....
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Yes, the DPF will trap all (well almost all) the smoke particulate material on the structure and oxidise it to CO2 when the conditions are right. Hence no smoke unless it has a hole in it.
    Regular Member Ross DTi 2.2's Avatar
    Münster, NRW, Germany
    Quote Originally Posted by Ste
    Yes.
    I don't understand how this can be. There is no "timing" on a diesel engine as there are no spark plugs to time. The turbo gives a full charge of air all the time due to the fuel/air mix igniting on compression rather than sparking.
    There is no way to control valve-open duration because the engines don't have variators.
    The only thing I can see these boxes doing, is to increase the fuel pressure, thereby increasing fuel volume in the cylinder. This is fine up to a point, but only so long as you have enough air to burn all the fuel. The reason you have black smoke is that the fuel to air ratio is too high. Possible fixes for this are a free flowing air filter or lowering the setting of your box slightly.
    You won't lose any performance by lowering the setting on the box as the car is not burning all the fuel its chucking in on your present setting. Your mpg will improve though.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Ross.
    Your understanding of how high pressure common rail diesels works isn't quite right. The injection timing CAN and IS changed by varying exactly when the fuel is injected into the already compressed air charge. Yes, rail pressure can be changed aswell. BUT changing injection timing and fuelling amount will make most difference. Higher rail pressure is one way of allowing these changes to be made.
    Ross.
    Now I understand, it can be varied by changing the injector opening duration rather than the valve opening duration.
    Do you agree though that black smoke equals not enough air in relation to fuel?
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Timing is when the injector actually opens, fuelling amount is controlled by rail pressure and injection duration (longer duration and higher rail pressure = more fuel).
    High smoke, or particulate matter (PM), does indeed indicate incomplete combustion. It may not as simple as too little air though. In normal road car engines I would agree that the air is not flowing well enough. But in tuned engines this may not be the case.
    Diesel combustion process is VERY complicated. And injecting the same amount of fuel at different timings can have very different outcomes in terms of PM.
    Regular Member Ian's Avatar
    York
    the CR1 is, put simply, a resistor that lowers the pressure signal sent to the ECU by a said amount right across the rev range. The ECU respnds by upping the pressure in the common rail to what it thinks is the correct amount. The CRD2 on the other hand varies the fuel pressure throughtout the rev range, depending on what map is loaded onto it. Injector timings are not affected by the boxes.
    So cdtisri, I would do as Ross DTi 2.2 says and turn it down a notch.
    Nicking Ya Dinner.
    You need NiCARette patches for it.
  1. Smoking
    By Hursty103 in forum Engine & Drivetrain
    Last Post: 17th January 2012, 11:24
  2. smoking
    By andy76 in forum Vectra C / Signum Troubleshooting
    Last Post: 15th May 2010, 19:21
  3. smoking
    By dominic32 in forum Engine & Drivetrain
    Last Post: 24th June 2009, 23:20
  4. Smoking
    By lizard in forum Styling
    Last Post: 18th January 2008, 21:21
  5. No Smoking
    By VauxVeteran in forum General Chat
    Last Post: 8th July 2007, 12:01
