Thread: smoking 3.0 Signum
    Bridgwater
    Default smoking 3.0 Signum
    HI,
    Two questions for the all knowing amongst you.
    Firstly the car is getting smoking under hard acceleration, so much so that as the engine passes through 4k anything behind me dissapears.....
    secondly it seems to be very tappity, i have just changed the oil and filter using the genuine filter and VX oil (ouch)
    any info grately recieved.
    John
    member of the smoke patrol 230bhp+
    as for the smoke it could be a quick fix as it maybe a blocked airfilter leaves and dirt
    what oil did you use
    Mar 2007
    Beaconsfield, Bucks
    Before I stuck the tuning box on it was bad but had a look at the air filter, mine was awful, it looked like it had never been changed. After that it was OK, it would give out a light haze rather than thick smoke.
    Mine does the same now but thats only when the tuning box is on!!
    Bridgwater
    Will look at the filter and see what it looks like.
    As for oil it was bought from Vauxhaul so was the right oil for the engine.
    John
    Fife
    Does your car drive ok? Engine management light staying off?
    Is the fuel consumption decreased at all since you have noticed the smoke?
    Approx how many miles has the engine covered?
    Bridgwater
    Default mileage
    Quote Originally Posted by goonturbo View Post
    The car has done 86k, no deterioration in performance, i get between 36 and 42 MPG.
    There is no engine management light coming on either.
    John
    Fife
    Cool
    I had problems with a couple of signams that were smoking. First one was a sticking egr valve but that was also accompanied with a lack of power, Other one was a split intercooler hose, as well as knackered oil pressure seals in the turbo was pumping out plenty smoke. Is the smoke you see black or blue? One other thing is have the engine management checked, ask the garage to check it through either generic obd or generic obd can, get them to check for pending codes, pending codes are codes where the ecu sees a fault but the fault is not bad enough to warrant putting the light on. Hope this helps you. Cheers Dave
    Bridgwater
    Default smoking
    Hi, the smoke is black so no oil.
    John
    Fife
    Ifs its black its obviously overfuelling.
    I would be having the ecu interrogated, could be a number of things, ect fault, egr fault, blocked vac hose, the list goes on.
    Regular Member brifen's Avatar
    Fareham
    Vehicle : Vauxhall Vectra
    Engine : 1.9 CDTI 150
    It defo needs looked at (doesn't need me to tell you that) but another culprit could be the MAF sensor. Will cause your big black smoke problem.
    Post back with any diagnosis made or remedy.
    Bri.
  1. Smoking Signum 2.0T help
    By adierolfe in forum Engine & Drivetrain
    Last Post: 4th May 2012, 17:59
  2. Smoking Signum 3.0 v6 CDTI
    By natvx220 in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd August 2010, 17:56
  3. smoking 2.2 petrol signum
    By matt0785 in forum Engine & Drivetrain
    Last Post: 11th May 2010, 20:58
  4. Signum engine judder and smoking!
    By arkhan78 in forum Engine & Drivetrain
    Last Post: 20th February 2010, 17:09
  5. Smoking
    By cdtisri in forum Vectra C / Signum Car Chat
    Last Post: 25th October 2006, 13:52
