Thread: smoking 2.2 petrol signum
    falkirk
    Default smoking 2.2 petrol signum
    hi im rather new here and this is my first signum
    have an issue with it emmiting smoke from exhaust sometimes when warm em light is on when its smoking i get slight missfire and hesitation
    just wondering if any of you guys have heard of this before it goes to vx
    Regular Member benny's Avatar
    Feb 2006
    dudley
    when ya say smoke ...is it blue ...does it use oil .?......or is it black dark smoke ..? i take its a 22yh ? ....if it is u need the codes read to see what it is ...might be fuel presh reg or pump or it could be the swirl flaps in the manifold ...
    falkirk
    looks dark grey or black smoke lot of soot in exhaust tail pipes suspect over fueling as it only does it betwwn 3000 and above and only if accelerating hard its had fuel pump and sensor both brand new yes its the 22yh newer style version of the 22se
    Feb 2006
    dudley
    Quote Originally Posted by matt0785 View Post
    i would get the codes checked to be 100% but i would say its the swirl flaps either sticking or broke ....
    falkirk
    where are they located and do they just need checked and cleaned is it an easy enough job to do
    Feb 2006
    dudley
    if you find the oil filter and look to the left on the under side of the manifold you will see a rod .... try and move it with ya hand see if it is stuck / broken
    Regular Member Sambor's Avatar
    Elgin
    You have to take inlet manifold of.This job is for few hours to be done.I'V done this few weeks ago.It's no easy.One of my swirl flaps is chiped(No 3)And I don't know if I should replace it or no?
    falkirk
    right have checked the flaps all moving and in good condition have code read car and it says o2 sensor heater failed but hasnt given actual code to say what one as i gather these engines have 2 lambda sensors
    any idea's gays
  1. Smoking Signum 2.0T help
    By adierolfe in forum Engine & Drivetrain
    Last Post: 4th May 2012, 17:59
  2. Smoking Signum 3.0 v6 CDTI
    By natvx220 in forum Troubleshooting
    Last Post: 3rd August 2010, 17:56
  3. Signum engine judder and smoking!
    By arkhan78 in forum Engine & Drivetrain
    Last Post: 20th February 2010, 17:09
  4. smoking 3.0 Signum
    By kawajohn in forum Engine & Drivetrain
    Last Post: 1st December 2008, 01:25
