Results 1 to 10 of 13
Thread: Smoking Signum 2.0T help
    Regular Member adierolfe's Avatar
    Feb 2012
    Corris
    Angry Smoking Signum 2.0T help
    Please see video
    [ame]http://youtu.be/VMwr84Rd_wM[/ame]
    Last few days the Signum has had this white? smoke come from the exhaust. So far, it hasn't happened from a cold start, only when its been driven, parked up while I shop then restart. But is fine again once back up to temp.
    Engine temp is 90 C ish, car pulls away fine. Haven't noticed any oil or coolant loss, but will recheck once engine has cooled.
    Any help appreciated, even if its just a link to another thread that I missed while searching.
    Ade
    Feb 2012
    Corris
    Oh and the fumes proper stink whether smoking or not. Couldn't describe smell though.
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    have you managed to read the codes yet, without seeing them I would suspect a lambda sensor or EGT at fault seeing as it doesn't do this from cold..
    Feb 2012
    Corris
    Quote Originally Posted by Caveman_nige View Post
    I don't have a code reader (correct term?) I'll ask around now to see if anyone has one.
    Jun 2009
    South Coast
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    CTS running out and causing overfueling?
    Just a thought - seen it before.
    Feb 2012
    Corris
    Doing that I had code 1547
    Or 1546. Light stayed on after.
    Jun 2009
    South Coast
    oddly those codes relate to Aircon issues.
    Feb 2012
    Corris
    I should mention that the EML is on. Bought the car with it on being told its the o2 sensor.
    Jun 2009
    South Coast
    I would be inclined to suggest you disconnect your battery negative terminal for 30 minutes or more to reset the fault codes etc.. This will clear any stored faults and let it learn any new faults if it still has any, after driving it for a while read the codes again and we can see if there is any related code to this smoke issue you are having.
    white smoke in the exhaust can be caused by a few things..
    http://wiki.answers.com/Q/What_can_c...om_the_exhaust
    not wanting to jump to conclusions a good fault code could help narrow it down.. what year and milage is the car?
  1. Smoking Signum 3.0 v6 CDTI
    By natvx220 in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd August 2010, 17:56
  2. smoking 2.2 petrol signum
    By matt0785 in forum Engine & Drivetrain
    Last Post: 11th May 2010, 20:58
  3. Signum engine judder and smoking!
    By arkhan78 in forum Engine & Drivetrain
    Last Post: 20th February 2010, 17:09
  4. Smoking
    By James Stewart in forum The 'Off Topic' room
    Last Post: 5th March 2009, 21:26
  5. smoking 3.0 Signum
    By kawajohn in forum Engine & Drivetrain
    Last Post: 1st December 2008, 01:25
