Results 1 to 10 of 25
Thread: How good is your gear selection?
    Regular Member Readster's Avatar
    Plymouth
    Default How good is your gear selection?
    After much head scratching and peering at the selector bits and wondering why the clutch rattle lessens when you press the clutch pedal in I have to confess that I am stumped...
    Do GM clutches rattle??
    Is the Vec C gear change as smooth as a Ford? Or, are they all a bit notchy esp 2nd to 3th and 3rd to 2nd??
    Any thoughts welcomed
    lanark
    6 Post(s)
    Year : 2017
    don't have a problem with mine mate all seems well
    Regular Member MattW's Avatar
    Jul 2008
    Sheffield
    Mine is a lot better since having the gear box oil changed. They reduced the amount in the F40 to fix the issue
    preston
    Probably more like the dual mass flywheel rattling.
    Feb 2009
    Edinburgh
    mine squeaks but doesn't rattle.
    Jul 2008
    VXR where are you now
    16 Post(s)
    Trim : Nissan GT-R R35
    Engine : 3.8 twin turbo 700hp
    nines a bit notchy till its warmed up
    Feb 2009
    Stockton on Tees
    IMO the Vectra has always suffered from rubbish gear box's. Both my 2.0 DTi Vec B & Vec C where rubbish in the 2nd 3rd and 3rd 2nd change. A few friends always make comments about Vauxhall being able to make good cars, shame about the gear box!!! Plus as said above its worst when cold.
    Regular Member Tadpole's Avatar
    'I haven’t lost my marbles, they’re in a bag somewhere? .. '
    I have no complaints could be the way I drive ..................
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I sometimes have difficulty going from 1st to 2nd at high revs. I slightly crashed it again this morning doing a rapid gear change, and I'd just driven 60 miles.
    Other than that, no complaints. 4th to 5th is great with no clutch - just slide it in, oo er
    Plymouth
    The other odd thing is if you change quickly from 3rd to 2nd the selection is much better than a slow change. From 2nd to 3rd is better quick, but still crunches slightly...
    Clutch pedal fully depressed btw.
    Any ideas chaps...
  1. Clutch/Gear Selection problem
    By Thom in forum Engine & Drivetrain
    Last Post: 28th July 2012, 21:08
  2. Automatic gear selection removal help
    By influencd in forum Bodywork & Interior
    Last Post: 31st May 2011, 18:53
  3. Dodgy Gear selection
    By skidmark1 in forum Engine & Drivetrain
    Last Post: 16th February 2011, 11:02
  4. Stiff gear change, gear selection fine though
    By tramman in forum Engine & Drivetrain
    Last Post: 24th November 2009, 23:20
  5. Popping noise on gear selection
    By JagRigger in forum Engine & Drivetrain
    Last Post: 15th October 2009, 12:28
