Thread: Automatic gear selection removal help
    Regular Member influencd's Avatar
    Oct 2010
    Eversley
    Default Automatic gear selection removal help
    Heya all,
    Thought I'd crowdsource some advice as I'm stuck...
    I'm hunting down a rattle and I've pulled out all the centre console and round it's coming directly from the gear selection mechanism. It kicks in at about 2000rpm when in gear.
    Does anyone know how you disengage the cable so I can remove the unit and take it apart, or is anyone familiar with a rattle coming from it?
    Vaux have said it's £230 for an entire new unit though they do have some parts for it too, but I need to work out what's broken.
    I've checked haynes but is doesn't match up, it says there's a tab that you pop out but I can't see anything like it. Help please!
    Sigtuna Sweden
    Sorry i have not the answer to your question.
    But wondering how did you remove the gearknob?
    Is it just to pull it straight up and watch the nose?
    Oct 2010
    Eversley
    Heya,
    I actually wrote about it here: http://www.vectra-c.com/forum/showpo...8&postcount=14
    Hope that helps.
    BUMP! Anyone have an idea how to detach the cable?
    Oct 2010
    Eversley
    Buuuuuuuuump! Still stuck (Cable is quite literally) - Please help!
  1. Clutch/Gear Selection problem
    By Thom in forum Engine & Drivetrain
    Last Post: 28th July 2012, 21:08
  2. Automatic (cvtronic) gear surround removal - help
    By influencd in forum Bodywork & Interior
    Last Post: 21st February 2011, 13:48
  3. Dodgy Gear selection
    By skidmark1 in forum Engine & Drivetrain
    Last Post: 16th February 2011, 11:02
  4. Stiff gear change, gear selection fine though
    By tramman in forum Engine & Drivetrain
    Last Post: 24th November 2009, 23:20
  5. How good is your gear selection?
    By Readster in forum Vectra C / Signum Car Chat
    Last Post: 10th June 2009, 18:14
vectra c automatic rattles when in gear
