Results 1 to 10 of 14
Thread: Dodgy Gear selection
    Regular Member skidmark1's Avatar
    Sep 2010
    cornwall
    Vehicle : 2.2 Direct
    Trim : SRI
    Engine : YH 2.2 petrol
    Mileage : 85000
    Default Dodgy Gear selection
    Has anyone experienced their gear stick stiff when moving it from side to side, it wont return to the neutral position (between 3rd and 4th) when released out of gear, goes in and out of gear ok when you can locate them but with a struggle. Also I notice that you do not have to lift the gear stick surround to get it to go over to reverse, so if not concentrating it is easy to put it in reverse rather than first. 1.9 CDTI Sri 150, 07 plate
    50k on the clock
    Sep 2010
    cornwall
    Trim : SRI
    Mileage : 85000
    do you think its a problem with the gear stick or the gear box itself??
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    sound like gear linkage mate
    Regular Member Damo77's Avatar
    Petersfield, Hampshire
    Engine : 1.9 CDTi 8v
    Year : 55
    Mileage : 92,000
    I have exactly the same problem mark, so will be watching this thread and hoping its not serious and expensive (only had this car 8 months and its bleeding me dry ) 55reg 120bhp 6 speed box
    Hope some peeps on here can shed some light on it
    Sep 2010
    cornwall
    Trim : SRI
    Mileage : 85000
    read a bit on site and some say lower the oil level from 3.2l to 2.4l to help with smooth gear change, but this has a problem of like having a worn selector gate or the spring gone from the stick itself, if that makes sense.
    Regular Member Aikon58's Avatar
    Englandshire
    Vehicle : shatch- sports hatch
    Trim : cheap plastics
    Engine : metal
    Year : 1901
    Mileage : 999
    Was it a local car Rob ? it could well be worn,having to change gear's a lot down here i find.
    If it doesn't get any better,i will give you a phone number of a vauxhall mechanic i some times use,who might be able to help.
    Year : 55
    Mileage : 92,000
    Yep same symptoms
    The gear selection is smooth between gears but it feels like a spring has broken off the base of the gearstick and stopping the gearstick from auto-centering.
    Just found that mine is the M32 gearbox (6 speed) and having googled it, it seems that the M32's are made of chocolate.
    From what I've read the 32 in the gearbox name is derived from the max torque level it is designed to handle - 320 nm. Think the 150 puts out 320 so its right on the level so I'm guessing adding a box or a remap takes the 1.9 way over the safe line and so therfore gearbox is stressed beyond it's intended capacity. (so not good for my next plans for the car then REMAP/tunning box ) even though mine is only the 120 version
    Would be great if this was just a matter of a small adjustment needed but not having seen the underside of the gearstick area I've no idea where to start looking/fiddling
    Off abroad next weekend for around a month as well so not going to get much chance to look either .
    Touch wood someone who's had this happen to them and had it fixed can put us on the right track
    Sep 2010
    cornwall
    Trim : SRI
    Mileage : 85000
    car is completly standard apart from a tow bar fitted by first (last) owner does not look like its done a great deal of work.
    north east
    Have a look under the gaiter there is a electical connection far to close to one of the rods this may have got tangled / trapped under the rod.
    Year : 55
    Mileage : 92,000
    Cheers for that Roswell think I'll try get the gear gaitor up and have a look and see what I can find
    Rob not sure if this is of any help to you (not sure what gearbox you have??) but just found a HOW-TO for adjusting the cables on the F40 gearbox
    Link to the HOW-TO
    Think, I'm going to have to brave the weather and get my hands dirty
    Hope it helps matey
    Damo
  1. Clutch/Gear Selection problem
    By Thom in forum Engine & Drivetrain
    Last Post: 28th July 2012, 21:08
  2. Automatic gear selection removal help
    By influencd in forum Bodywork & Interior
    Last Post: 31st May 2011, 18:53
  3. Stiff gear change, gear selection fine though
    By tramman in forum Engine & Drivetrain
    Last Post: 24th November 2009, 23:20
  4. Popping noise on gear selection
    By JagRigger in forum Engine & Drivetrain
    Last Post: 15th October 2009, 12:28
  5. How good is your gear selection?
    By Readster in forum Vectra C / Signum Car Chat
    Last Post: 10th June 2009, 18:14
vectra c gearstuck spring broke site:www.vectra-c.com
vectra 1.9 tdi gear linkage adjustment
