Thread: Cleaning Throttle Body, 2.0T
    May 2008
    Scottish Highlands
    Default Cleaning Throttle Body, 2.0T
    Normally when I'm cleaning a throttle body with spray cleaner, I remove the air filter and spray the cleaner up the air intake to clean the throttle body a bit.
    Can this be done on the 2.0T or what is the best option for cleaning the throttle body?
    Also how often are the spark plugs supposed to be changed on the 2.0T Z20NET?
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    Dont know about the 2ltr turbo mate but on my 2.2 direct i pull the pipe off the top of the Throttle body its only one of them Bast@rd clips once off you can see the butterfly just spray that till its new and shiny
    Regular Member Super T's Avatar
    May 2007
    On the Levels
    VX recon 10k on the spark plugsBut for what they cost 15/20k will do.
    Tyneside
    Quote Originally Posted by Super T View Post
    VX trying to rob os once again with that one, no chance do they only have 10k miles use in them.
    Regular Member bigun's Avatar
    Feb 2007
    Newcastle UK
    Funny you should say that tho. My mechanic changed mine when I got it serviced in August. I've done 19k miles in my Ed100 this year and he asked if it'd been running rough. I said it been ok but then driving it all the time I might not notice a decline in performance. He said the plugs were well knackered (showed me them and they def looked shot) and I should consider changing them every 10k as he thought 20k was too far. I've used him for years and he's superb so I'm inclined to agree. 10k nearly done again so it'll be off for a change so we'll see if he's right. (yes, 10k in 3 months, scary!)
    May 2008
    Scottish Highlands
    according to service manual it's 80k?
    Tyneside
    Quote Originally Posted by sriturbo View Post
    Yep it does that, just checked mine. Although I wont be leaving them that long.
    May 2007
    On the Levels
    With the cars running BSR stage 1 15k is ok! thats what mine did but the tech did say i was silly to change them!(they were ok)But with stage 3 10k sounds ok.
    You won't be able to do that on the 2.0T - there's the small matter of a turbo sitting in between your air intake/filter and the throttle body.
    If you need to clean it then the best bit is to remove the boost hose going into it and clean it that way. You'll see the butterfly exposed when you remove the big boost hose - TB is situated on the front of the engine under the engine cover.
    Nov 2007
    North Wingfield, Chesterfield, Derbyshire
    Vehicle : Vectra C Hatchback Facelift
    Trim : Club
    Engine : Z18XE
    Mileage : 100085
    confused
    Quote Originally Posted by Sean-2.2Direct View Post
    Thought about doing it this way on our 55 reg Facelift Club with the Z18XE engine with carb/injector cleaner spray...about 35K on the clock...did/do you run the engine at low revs (about 2K)while spraying the butterfly and throat until clean ??? Or did you clean it 'closed' and mop-up the fluid left in/on it???
    Comments would be appreciated...
    Thanks & Cheers
  1. Tickover Issues After Cleaning Throttle Body
    By Telboy in forum Engine & Drivetrain
    Last Post: 27th November 2012, 22:58
  2. Spanner Light After Cleaning EGR & Throttle Body
    By john506 in forum Engine & Drivetrain
    Last Post: 5th September 2011, 18:53
  3. Spanner Light after Cleaning Throttle Body
    Last Post: 28th May 2011, 20:30
  4. Cleaning of Throttle body EGR & new Sparkers
    By Sean-2.2Direct in forum Engine & Drivetrain
    Last Post: 1st July 2010, 06:33
  5. Cleaning throttle body?
    By biggiepop in forum Engine & Drivetrain
    Last Post: 20th November 2008, 01:47
