Thread: Tickover Issues After Cleaning Throttle Body
    Regular Member Telboy's Avatar
    Apr 2006
    Leeds
    Default Tickover Issues After Cleaning Throttle Body
    Well my little issues with car being a liitle hesitant and tickover dropping down every so often are sorted now after taking throttle body off and giving a a thorough clean with carb cleaner. Now the car has gone a little silly on the tickover. It drives lovely but when you you let of the throttle it holds at 1500 revs for about 30 seconds then drops down to 700rpm. Its a bit of a cow when in traffic. I noticed and was very suprised to see there is no paper gasket on the throttle body as well just the rubber seal, is this normal.Could this just be something simple its got me baffled.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Just smear a little engine oil on the seal and dont over tighten it. Take off the battery for 20 mins (making sure you have the stereo code) and then the idle should sort itself out. the ECU has become used to the amount of air it was getting with a dirty throttle body, now you've cleaned it its getting more air than it's used to so it has to re learn. Its this gap around your butterfly that controls the idle.
    Apr 2006
    Leeds
    Rushy to the rescue again. Thanks for that info very much appretiated. I will get that sorted when back home as away with work. I was suprised how much it was carboned up and even more suprised when the car wouldn't stop on way to work.
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    No probs m8. The only other thing it could be is an air leak caused by over or under tightening of the TB bolts. A good nip up is all they need.
    HTH
  1. Spanner Light After Cleaning EGR & Throttle Body
    By john506 in forum Engine & Drivetrain
    Last Post: 5th September 2011, 18:53
  2. Spanner Light after Cleaning Throttle Body
    Last Post: 28th May 2011, 20:30
  3. Cleaning of Throttle body EGR & new Sparkers
    By Sean-2.2Direct in forum Engine & Drivetrain
    Last Post: 1st July 2010, 06:33
  4. Cleaning Throttle Body, 2.0T
    By sriturbo in forum Vectra C / Signum Car Chat
    Last Post: 16th July 2009, 20:24
  5. Cleaning throttle body?
    By biggiepop in forum Engine & Drivetrain
    Last Post: 20th November 2008, 01:47
vauxhall vectra z22se how to clean throttle body
throttle body butterfly gap
