Results 1 to 10 of 13
Thread: Spanner Light After Cleaning EGR & Throttle Body
    Regular Member john506's Avatar
    Mar 2011
    Wirral
    Default Spanner Light After Cleaning EGR & Throttle Body
    As the title suggests.
    It comes on when I start my car then will go off after a few minutes of driving.
    Anything to worry about?
    Thanks!!
    wirral
    59 Post(s)
    Vehicle : vauxhall vivaro
    Trim : Basic
    Engine : 1.9
    Any codes mate? Is everything back in plac correctly?
    Mar 2011
    Wirral
    Yep put everything back as it was, haven't had the codes checked.
    I did lose that metal seal that connects to the bottom of the EGR, would that cause the spanner light to come on?
    I blanked my EGR off tonight but haven't had a chance to check for the spanner light as it was raining, I was wet, and I had some desperados waiting for me in the fridge
    Jun 2011
    Elland
    Standing outside in the rain... beer in the fridge + dry........
    So did the spanner light come on after you cleaned the EGR, or blanked it...? Also if you can find out what the code is / are, that would be great.
    Generally, blanking the EGR will cause a code / spanner / emissions light, but it can be mapped out readily on the 1.9s and you can have a few more ponies mapped in at the same time
    wirral
    59 Post(s)
    Trim : Basic
    Engine : 1.9
    A think blanking it might be doing it mate.
    I'm not back till the weekend now. But if your still having dramas give me a shout and I'll plug car in for ya.
    Mar 2011
    Wirral
    Just that I cleaned the EGR & Throttle Body about a month ago and spanner light has been on since then (only 5 mins or so till I get driving)
    I blanked it when I got home earlier but didn't turn the car over or anything to check if the light was on or not.
    I will check tomorrow and see if it is on in the morning then re-post tomorrow afternoon/night.
    Thanks CritchvxD I appreciate that mate!
    Jun 2011
    Elland
    Good job! Get the codes read and see what it's complaining about
    Jul 2009
    Brighton
    Did you use new gaskets for the EGR and TB?
    I hear the TB throws an EML light if it's leaking even a little bit.
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Did you get this sorted dude? On the Wirral too (Bromborough) and don't mind plugging a laptop in for you if you can't find the problem.
    Regular Member monty2000's Avatar
    Sep 2009
    swansea
    Vehicle : Vectra C Pre Face, Colour Coded, CR Tech Box, Pipercross Panel filte, Blanked EGR :-)
    Trim : Club
    Engine : 1.9cdti 16v
    if its going out it could be a stored fault code.
  1. Spanner Light after Cleaning Throttle Body
    By john506 in forum Engine & Drivetrain
    Last Post: 28th May 2011, 20:30
  2. Cleaning of Throttle body EGR & new Sparkers
    By Sean-2.2Direct in forum Engine & Drivetrain
    Last Post: 1st July 2010, 06:33
  3. Spanner Light, Throttle Body
    By rsocon in forum Engine & Drivetrain
    Last Post: 28th October 2009, 23:04
  4. Cleaning Throttle Body, 2.0T
    By sriturbo in forum Vectra C / Signum Car Chat
    Last Post: 16th July 2009, 20:24
  5. Cleaning throttle body?
    By biggiepop in forum Engine & Drivetrain
    Last Post: 20th November 2008, 01:47
