Results 1 to 10 of 22
Thread: Factory subwoofer - retrofit?
    Regular Member MrT's Avatar
    Near Durham
    Question Factory subwoofer - retrofit?
    Quick Q:
    Where is the factory-installed subwoofer fitted? (facelift, CDC40)
    Also, is it possible to retro-fit this? (parts list needed please!) The car has the 8-speaker system installed (main and tweeter in each door), with fairly beefy lower front door speakers - but there's a blank where there would normally be a separate slider for the sub-volume on the centre display.
    Wife and three kids to ferry about - cannot afford boot space for a custom job.
    Cheers!
    Subwoofer? No mention of it on the PDF specs for a 2006 facelift model. CDC40 lists 7 speakers only, as does the CD70.
    Oct 2007
    Shropshire
    8 speakers are the four doors; mid/bass and tweeter in each, the extra nineth speaker is the centre one in the dash, not and sub.
    Regular Member steve1975l's Avatar
    Mar 2008
    Surrey
    Here is a sub I had in the Audi hidden behind the wheel arch, the amp is hidden behind the rear quarter. I toyed with the idea of making a box to go in the Vec right cubby hole.
    Come on who's good at wood work...could sell sub boxes to all us forum members.
    Near Durham
    Quote Originally Posted by steve1975l View Post
    Nice work - what screen did you have for the PS2??? This'd be an option for the OSR boot cubby - although currently I have a fire extinguisher mounted in there. Was that just a random storage bin, or was something more formal planned for the space? I've also added the warning triangle and first aid kit in the other side - they at least have moulded storage spaces provided as part of the support for the rear fuse box and alarm siren.
    Am gradually going nuts trying to locate where I saw it referenced - IIRC the whole 'speaker thing' was not as expected, and I was expecting the car to have an odd number. It definitely has 8, and I'm referring back to the centre audio display options when spotting the planned presence of the sub volume control slider in some versions. I've been back through the v1 facelift PDFs to see if I can find it listed - am now scouring for CDC40 specsheets - at this hour... will need to get the owner's manual out and have a check there.
    Mar 2008
    Surrey
    I cut the latest Audi sat nav to fit. I found that if you code it as an A6 you will get the instructions in the instrument cluseter. I found that in most cars you needed to pick up the CAN connection from behind the cluster. I wrote a 40 page guide on the subject and have helped at least 50+ people to do it so far.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Mileage : 137000
    Loads of room behind the right hand side.
    I fitted a baffle only set up but it was pants, using a sub and amp from an old Vibe active system. Think you just need to build the box, then go to any decant audio shop with the internal volume of the box and they will give you the correct sub.
    Regular Member Preey's Avatar
    May 2008
    Hudd
    looks nice whats it sound like ?
    Regular Member andymagee1982's Avatar
    May 2008
    Widnes.
    Looks mint.
    I would love to doo this also.
    Q? How do you replace bulbs?
    Vehicle : 9-3 Wagon
    Mileage : 137000
    LOL, you have to pop the trim off. VX failed me on my first MOT for not having orange enough indicator bulbs. They were stock bulbs and they fitted a set without asking and charged me. Bet they got a shock when they opened the hatch up.
  1. Retrofit ESP ? what do i need....
    By kenp in forum Handling & Braking
    Last Post: 4th June 2012, 17:27
  2. IDS retrofit
    By R2XPT in forum Handling & Braking
    Last Post: 28th September 2011, 20:53
  3. Retrofit
    By Jabbekot in forum Styling
    Last Post: 1st April 2010, 22:22
  4. Retrofit Aux In
    By leeds vectra in forum Parts for sale
    Last Post: 26th December 2009, 17:29
  5. factory subwoofer
    By DennisTheMenace in forum Electrical & ICE (including SatNav)
    Last Post: 30th May 2006, 19:01
vectra c subwoofer
https:www.vectra-c.comforumshowthread.php73300-Factory-subwoofer-retrofit
vectra c met subwoofer
Does vectra c has factory subwoofer
vectra subwoofer
vauxhall vectra boot build
opel vectra subwoofer inbouwen
vectra c subwoofer install
subwoofer inbouwen in vectra c
subwoofer vectra c
