Results 1 to 10 of 11
Thread: Retrofit ESP ? what do i need....
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Default Retrofit ESP ? what do i need....
    Hi Guys
    well i was thinking about retrofitting ESP to my car...
    It has TC and ABS..
    What i do know its missing is the "Rotation rate" sensor that should be around the gearleaver area.
    But what else would i be missing that i needs to change?
    (even I was in dought if it should be here under breaking and handling or Electrical).
    Ken
    May 2011
    Ashby-de-la-Zouch
    Trim : sri nav/Elite
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    pm plasma he told me hes going to do it to his car.
    Engine : 2.2 Direct
    I would assume it has a different ABS module, as mine is marked ABS-ESP
    The interaction with the rear ABS sensors is different
    May 2011
    Ashby-de-la-Zouch
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    i just want to fit normal tc as mine being a face-lift don't have it. am always wheel spinning lol.
    Engine : 2.2 Direct
    holy smoke.. just checked how many different modules there are
    Engine : 2.2 Direct
    Quote Originally Posted by dan danz View Post
    Even with TC you can still spin your wheels.. (but not if you have ESP)
    May 2011
    Ashby-de-la-Zouch
    Engine : CDTI 150
    Year : 56
    Mileage : 130ish
    Quote Originally Posted by kenp View Post
    it will make no difference if you have esp. esp uses the brakes when your car slides.
    I can spin mine too, the TC on the Vectra C is very poor
    I can even do it in fourth gear!
    The main benefit is the ESP on roundabouts, or where oversteer is highely likely, not that the car should be driven like that...
    Engine : 2.2 Direct
    What are you sure ;-)
  1. IDS retrofit
    By R2XPT in forum Handling & Braking
    Last Post: 28th September 2011, 20:53
  2. AFL retrofit
    By yoyovento in forum Electrical & ICE (including SatNav)
    Last Post: 12th May 2011, 13:16
  3. AFL Retrofit
    By davedrinks in forum Electrical & ICE (including SatNav)
    Last Post: 5th December 2010, 19:16
  4. Retrofit
    By Jabbekot in forum Styling
    Last Post: 1st April 2010, 22:22
  5. Retrofit Aux In
    By leeds vectra in forum Parts for sale
    Last Post: 26th December 2009, 17:29
