Likes Likes:  1
Results 1 to 4 of 4
Thread: Electric seat pin out
    Nov 2010
    Shropshire
    Vehicle : Insignia Ecoflex
    Engine : 2000 diesel
    Year : 2013
    Default Electric seat pin out
    I've tried searching but surprisingly haven't found an answer to my query. I'm trying to fit a replacement passenger seat, swapping from a basic manual one to an electrically adjustable one to match the drivers seat
    The seat (second hand) came with a large plug attached but I'm assuming the requisite socket won't already be wired in?
    That being the case I need to know which pins I need to connect to a 12v feed. There are far more wires than I had anticipated.
    I've already identified the height adjuster connections but that still leaves the lumber suport and air bag (if there is one) to sort out. I don't care about memory function (if there is one) and I don't know if the seat is heated but if it is it would be nice to get it working.
    Is anyonee able to help please, particularly with the lumber support adjuster?
    Administrator plasma's Avatar
    Mar 2006
    On the Forum
    579 Post(s)
    Engine : 150
    Year : 05
    Mileage : 74000
    drop me a message at plasmasrepairs@gmail.com and I will send you over all the info I have for it.
  3. Likes soulman liked this post
  4. #3
    Nov 2010
    Shropshire
    Year : 2013
    Brill. Thank you very much ��
  5. #4
    Nov 2010
    Shropshire
    Year : 2013
    All sorted. I simply piggy-backed from the wiring on the drivers seat and it's all working now. I guess ideally it should be on it's own fused supply but both seats are never likely to be adjusted at the same time so I'm happy with that solution.
  1. Electric seat owners help please
    By Kev_A in forum Vectra C / Signum Car Chat
    Last Post: 9th April 2011, 22:39
  2. heated seat switches? also electric seat adjust questions?
    By big rich in forum Vectra C / Signum Car Chat
    Last Post: 26th November 2010, 11:48
  3. Electric Seat Upgrade
    By dieselvec1 in forum Bodywork & Interior
    Last Post: 1st August 2010, 16:32
