View Poll Results: Did the Fiat Gasket work on your 150 cdti
Voters
66. You may not vote on this poll
  • Yes - Fiat gasket fitted and all ok
    58 87.88%
  • Yes - Fiat gasket fitted and NOT ok - Spanner / Fault code
    8 12.12%
Page 2 of 11 FirstFirst 1234 ... LastLast
Results 11 to 20 of 103
Thread: Fiat EGR Gasket for a 150 CDTI
  1. #11
    UK
    Mine has been fitted for 10,000's of miles with no faults or issues. Car is 2006 1.9cdti 150.
    Edit: I only fitted the large square one.
  2. #12
    Regular Member AntSSSS's Avatar
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Year : 2008
    Mileage : 100k
    Quote Originally Posted by Dan_BlackSRi View Post
    There was a software update for the EGR wasn't there, maybe the settings in that are very fine (to help with the issue) and the gasket reduces airflow too much for the new settings? (just guessing to be fair).
    All I can think of too - and makes sense..........
  3. #13
    Feb 2010
    EIRE
    Put this on my SAAB 1.9tid and no enigme management light.
  4. #14
    Regular Member lofty's Avatar
    Sep 2007
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    Pick mine up on sat so will find out this weekend.
  5. #15
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    I've just fitted the Fiat mod I bought from AntSSS & happy to report the car is running fine without any warning lights - the manifold/egr was replaced a couple of months back & although it was black inside the egr it's just on the surface with no accumulation - the boost sensor was cleaned out Wednesday & that was filthy
  6. #16
    Oct 2007
    Scotland
    Anyone got a Fiat part number for this?
    I went in to ask for one and instead of getting a blank plate I got a blank look
    Cant you just clear the fault code?
  7. #17
    Mar 2007
    Southport
    The one I fitted is P/N 55225287
    Not without the appropriate equipment but it will clear itself after about 25 starts I think
  8. #18
    Regular Member yzf1kr's Avatar
    Mar 2009
    Netherlands
    Fitted plate to 05' Vectra Estate.
    No problems.
  9. #19
    Regular Member markm's Avatar
    Oct 2006
    Portsmouth
    Got mine to fit, I've run a few jars of Forte in the last two tanks of fuel and was going to get some 10K Boost or EGR3 from Wynns to finish off the internal clean before I fit the gasket,
    how long will it take to fit ?
  10. #20
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Quote Originally Posted by markm View Post
    Very quick job, about 15 mins to remove and refit with the new gasket.
  1. fiat egr gasket,what difference does it make?
    By mike. in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2013, 19:48
  2. Fiat EGR Gasket Question....
    By Dan_BlackSRi in forum Engine & Drivetrain
    Last Post: 9th August 2012, 16:25
  3. Cdti 120 EGR Fiat gasket - Details required
    By alcutler in forum Engine & Drivetrain
    Last Post: 8th July 2011, 08:04
  4. Fiat EGR Gasket
    By bafoo in forum Engine & Drivetrain
    Last Post: 20th January 2011, 16:51
  5. Fitted Fiat EGR gasket.
    By Stuarty in forum Vectra C / Signum Car Chat
    Last Post: 18th November 2009, 19:58
vectra cdti egr gaskets
