Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: Fitted Fiat EGR gasket.
    Regular Member Stuarty's Avatar
    Aberdeenshire
    Thumbs up Fitted Fiat EGR gasket.
    Just a quick post to say that i have fitted the fiat egr gaskets to my 150 cdti and its running better seems to be running smoother and have a bit more punch i also cleaned the boost sensor while i was at it so if anyone is considering doing this i would reccomend it as it didnt take long to do and there is noticable improvment to the way the car is running.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    is their any difference between a vx egr gasket and a fiat one ??.
    Aberdeenshire
    Yes there is mate the fiat gasket is more like a blanking plate but has some small holes in it to let some exhaust gasses through so the ecu is not upset.
    Aberdeenshire
    heres the thread where i found out about it pics and fiat part numbers are in there. http://www.vectra-c.com/forum/showth...+gasket&page=2
    Regular Member Pete B's Avatar
    Malvern
    Quote Originally Posted by Stuarty View Post
    I suspect that it's mainly the cleaning of the EGR valve & boost sensor that's making the car run better rather than the new gasket as such. The Fiat gasket should keep the system cleaner & running better for longer though as less exhaust gases will be recycled through and less soot deposited as a result.
    As a matter of interest did you fit both the normal & blanking gasket on the manifold side of the EGR & if so, which way round?
    i.e. Did you fit the blanking bit the manifold or EGR side of the normal gasket?
    Aberdeenshire
    I put the metal plate on then the other gasket so it was the normal gasket against the inlet manifold if that makes sense lol i removed the vx one as it was shot.
    Regular Member axelf's Avatar
    chester le street
    do this need doin to the 120 engine??????
    Jun 2009
    doncaster
    F.i.a.t-fix it again tomorrow!
    Aberdeenshire
    Fiats prob need fixed less than crappy vauxhalls!
    Jun 2009
    doncaster
    dont be silly
  1. fiat egr gasket,what difference does it make?
    By mike. in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2013, 19:48
  2. Fiat EGR Gasket Question....
    By Dan_BlackSRi in forum Engine & Drivetrain
    Last Post: 9th August 2012, 16:25
  3. Fiat EGR Gasket for a 150 CDTI
    Last Post: 6th June 2012, 10:04
  4. Fiat EGR Gasket
    By bafoo in forum Engine & Drivetrain
    Last Post: 20th January 2011, 16:51
  5. Cleaned out the EGR and fitted Fiat Gasket today
    By merikiito in forum Engine & Drivetrain
    Last Post: 28th June 2010, 22:10
