Page 1 of 10 123 ... LastLast
Results 1 to 10 of 98
Thread: Fiat EGR Gasket Question....
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Default Fiat EGR Gasket Question....
    Right then, I now have the gaskets that I ordered from Fiat they are the two square ones pictured....
    but do they do a semi-blanking gasket for the oval side too..? They had a search but couldn't find one, only the standard one (pictured).
    What did other people get from Fiat...???
    Lancashire
    Trim : XP1
    Mileage : 66000
    Looks like this is needed too...
    71751469 - Modified/Swirl Gasket - 1 Required Approx £12 - Shown Centre
    46773082 - Standard Gasket - 2 Required approx £1.80 - Shown Left & Right
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Dan,
    How come you have two big gaskets- - did you order 2 or is that how it comes?
    Ive ordered these but arrive Thu as the small one was coming from Italy
    Anthony
    Lancashire
    Trim : XP1
    Mileage : 66000
    The top big one is a metal plate which was £12 and the other sqaure one with the red edging (a proper gasket) seems to be exactly the same, but was only £4 (from Italy) I was a bit confused too (used the part numbers off this forum). It seems silly to semi blank this side only, as the EGR will still have the same amount of crud entering it as before, just not as much leaving (surely will block quicker) - so need some for the inlet side, like I posted above.
    Middlesex
    Trim : SRI
    Mileage : 100k
    OK trying to work this out
    So I have ordered:
    1 x 71751468
    1 x 55225287
    Looks like the same as you from what I can see on your invoice - but you have three there.. Or is the third small oval just there as thats what you are asking about..
    A
    Middlesex
    Trim : SRI
    Mileage : 100k
    OK I see...
    So for the small oval ones - we need all three?? or just the blanking and an oval gasket?
    A
    Jun 2009
    dunstable
    the red gasket is is the revised replacement for part no 55191883 (£3.19+ vat). some delaers still have the above part, but most will give you the red one (£4.04 + vat). What you need to do , is ask the dealer to to order the original part no above, and show him a picture.
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by AntSSSS View Post
    OK I see...
    A
    It seems all three are needed, as the metal blanking plate doesn't provide enough seal on its own, so the std gaskets are used either side of it to make sure it seals ok - these appear the same as on the 120 too.
    Middlesex
    Trim : SRI
    Mileage : 100k
    Just called Fiat Slough and they have the oval blanking plate in, but not the two standard ones. Getting me them for tomorrow when I pick up the other two.
    OK - so the std ovals sandwich the blanking plate, thats fine.
    How do the big ones work then? do you need to fit both still?
    (isn't this fun! )
    A
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by ak47 View Post
    Is the red one not ok then... I have that one and the blanking plate too.
    Have you fitted these, which one did you get for the exhaust gas side..?
  1. Fiat EGR Gasket for a 150 CDTI
    Last Post: 6th June 2012, 10:04
  2. Fiat 16v diesel gasket for Z19DTH
    By lee gsi in forum Vectra C / Signum Car Chat
    Last Post: 9th March 2011, 20:43
  3. Fiat EGR Gasket
    By bafoo in forum Engine & Drivetrain
    Last Post: 20th January 2011, 16:51
  4. fiat doblo head gasket??
    By nigec in forum The 'Off Topic' room
    Last Post: 18th July 2010, 21:59
  5. Fitted Fiat EGR gasket.
    By Stuarty in forum Vectra C / Signum Car Chat
    Last Post: 18th November 2009, 19:58
modified fiat egr gasket
71751469 55225287
71751469
fiat modified gasket
fiat modified egr gasket z19dt
EGR 71751468
1.9cdti egr modified gaskets fiat
egr fiat gasket
71751468
55191883 egr
fiat 71751468
