View Poll Results: Did the Fiat Gasket work on your 150 cdti
Voters
66. You may not vote on this poll
  • Yes - Fiat gasket fitted and all ok
    58 87.88%
  • Yes - Fiat gasket fitted and NOT ok - Spanner / Fault code
    8 12.12%
Page 1 of 11 123 ... LastLast
Results 1 to 10 of 103
Thread: Fiat EGR Gasket for a 150 CDTI
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Default Fiat EGR Gasket for a 150 CDTI
    So - poll to find out if anyone has actually fitted the Fiat blanking plate style gasket to a Vectra CDTI 150 and had success, i.e no spanner light / fault code?
    Me:
    Vectra 2005 CDTI 150
    New Inlet fitted 1 year ago. Fiat style gasket fitted today and P0400 fault code thrown straight away..
    No Success.
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Fitted mine, all ok, no problems.
    Fitted one to a mates 150 also, his is also fine.
    Mine is a 2004, mates a 2007.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    did you fit the new square one or the oval one ? or both?.
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by the-wizard View Post
    Just the new square one, as the (semi-blanking) oval one isn't for the 150 EGR.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    surprised you dont have issues as I can only imagine the soot would be choking the egr valve??
    Gazza4
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    so they say!,but some people have fitted both. i have the square one ready when i replace the manifold.
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by Gazza4 View Post
    Gazza4
    Not at all, the gasket increases the airflow within the EGR (by creating a kind of swirl effect) which helps keeping it cleaner.
    Fiat and Alfa have been using these for a while now with a major decrease of EGR failures reported (especially in Alfa's ).
    Regular Member OSSY's Avatar
    Apr 2009
    Thumbs up
    I have a 150bhp engine and I've fitted the rectangular plate, but not the genuine fiat one - i made my own out of a 7up can. I took the EGR off to clean and stenciled around the end that fits my (new) inlet manifold.
    After I'd done 1,000 miles i took the EGR valve off to see what the make shift 7up gasket looked like, and it looked the same as when i put it in...
    I've not had any performance issues! but i think its a little less power/responsive, sometimes under higher gears (4-6)... It seems to be noisier too!!! all this might just be done to my paranoia...
    All this aside, if it prevents unnecessary amounts of soot entering the inlet manifold only to reduce certain exhaust gasses - i can live with redirecting all these peaces of unnecessary amounts of soot straight out the exhaust...
    Middlesex
    Trim : SRI
    Mileage : 100k
    Well - I don't know what to make of that - why would it work on one and not the other..
    Only thing that I can think of is Software levels in the ECU.. When mine went in for the 3rd injector mod - they updated the software which was (apparently) a good few versions behind.
    Again when they changed the Inlet there was an item on the invoice (all be it FOC) for an update to engine software.
    Maybe the newer software is more sensitive to the EGR flow - dunno!
    Lancashire
    Trim : XP1
    Mileage : 66000
    There was a software update for the EGR wasn't there, maybe the settings in that are very fine (to help with the issue) and the gasket reduces airflow too much for the new settings? (just guessing to be fair).
  1. fiat egr gasket,what difference does it make?
    By mike. in forum Vectra C / Signum Car Chat
    Last Post: 20th February 2013, 19:48
  2. Fiat EGR Gasket Question....
    By Dan_BlackSRi in forum Engine & Drivetrain
    Last Post: 9th August 2012, 16:25
  3. Cdti 120 EGR Fiat gasket - Details required
    By alcutler in forum Engine & Drivetrain
    Last Post: 8th July 2011, 08:04
  4. Fiat EGR Gasket
    By bafoo in forum Engine & Drivetrain
    Last Post: 20th January 2011, 16:51
  5. Fitted Fiat EGR gasket.
    By Stuarty in forum Vectra C / Signum Car Chat
    Last Post: 18th November 2009, 19:58
vectra cdti egr gaskets
