Thanks Thanks:  1
Results 1 to 8 of 8
Thread: Ball joint bolts problem advice
    Mar 2017
    northwest
    Vehicle : vectra c
    Trim : exclusive
    Engine : 1.8 VVT
    Exclamation Ball joint bolts problem advice
    Hi just had to replace my ball joint pinch bolt on vectra c 1.8 vvt z18xer.The bolt is an E16 torx M10 X 65MM.Rang up vauxhall to get a couple and was told they have stopped production of these so ended up getting one from scrappy.
    Was wondering would somethink like this have worked https://www.ebay.co.uk/itm/163125696...Cclp%3A4429486
    Looks like the dealers are slowly stopping selling certain parts..maybe they want us all to go electric.Think people need to be aware if you plan on doing work on your car.
    Sep 2014
    uk
    Engine : 1.9 cdti 150 x 3
    Year : 08/07
    Yes to the bolt it's probably the grade that the original is. As for the availability of parts the last vectras were made 2008 is it any wonder parts are not available.
    Mar 2017
    northwest
    Vehicle : vectra c
    Trim : exclusive
    Engine : 1.8 VVT
    Cheers for response..The trouble is some parts are the same found on other vechicles .Also a mechanic said the same that certain parts are either on back order and never actually come available or are being discontinued even on some later models.
    Oct 2013
    Derby
    340 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    I wouldn’t it will rust instantly, get one with a flanged head that’s plated.
    Teapot Tuned 255/300
    Tech2 & MDI diagnostics + SPS
    Mar 2017
    northwest
    Vehicle : vectra c
    Trim : exclusive
    Engine : 1.8 VVT
    hi cheers,you don't have a link to one do you as not sure which would be ok.
    Regular Member Fastcabs's Avatar
    Aug 2017
    Glasgow
    Vehicle : Vectrarri
    Trim : Not any more
    Engine : Z19DTH
    Mileage : 141500
    FYI
    Hey, check out LEMFÖRDER Repair Kit, wheel suspension in the AUTODOC app https://m.autodoc.co.uk/lemforder/13787925
    Well worth it if you’re ordering other stuff. I’ve had these on my car for a couple of years now with no issues. They do start to rust but no more than the original GM ones.
    Aug 2017
    Glasgow
    Vehicle : Vectrarri
    Trim : Not any more
    Engine : Z19DTH
    Mileage : 141500
    Quote Originally Posted by automan View Post
    That link is for all the front wishbone bolts.
  8. Thanks automan thanked for this post
  9. #8
    Mar 2017
    northwest
    Vehicle : vectra c
    Trim : exclusive
    Engine : 1.8 VVT
    Quote Originally Posted by Fastcabs View Post
    cheers .
  1. Bottom ball joint.
    By GrannySmiff in forum Vectra C / Signum Car Chat
    Last Post: 26th May 2013, 11:21
  2. MOT Failure Anti-roll bar linkage ball joint problems need advice
    By Bartekuk in forum Suspension, Wheels & Brakes
    Last Post: 14th January 2013, 13:10
  3. Ball joint issues
    By hothatch in forum Suspension, Wheels & Brakes
    Last Post: 19th February 2011, 21:46
  4. Gearknob ball joint
    By george1987 in forum Vectra C / Signum Car Chat
    Last Post: 21st April 2010, 21:57
  5. bottom ball joint
    By paulvectrac in forum Suspension, Wheels & Brakes
    Last Post: 19th March 2010, 14:23
https:www.vectra-c.comforumshowthread.php238041-Ball-joint-bolts-problem-advice
