Thread: Ball joint issues
    Full Member hothatch's Avatar
    Nottingham, emec#7
    Vehicle : Insignia
    Trim : SRI NAV
    Engine : 1.6T 180 ECOTEC
    Year : 2012
    Default Ball joint issues
    My friend recently had an Astra serviced at vauxhall and they inspected that the ball joint is loose. Not so sure if its true, How can i tell when the ball joint is loose/on way out, apart from looking under the car? Can i tell by driving the car?
    Engine : 1.9 CDTi
    Depends what ball joint it is.
    Nottingham, emec#7
    Vehicle : Insignia
    Trim : SRI NAV
    Year : 2012
    Not too sure.
    Full Member vectraturbocal's Avatar
    Aug 2010
    leeds
    if its bad then you will feel knocking when turning also the car will pull slighty or bad (depending on how bad it is) jack it up under the wishbone so that the wheel is just off the floor and bar under the tyre if its going you will feel lift in the wheel and also hear it, but you have to jack it on wishbone otherwise you will feel lift fron the wishbone bushes
  1. spinning ball joint
    By neill in forum Suspension, Wheels & Brakes
    Last Post: 7th August 2011, 21:09
  2. failed MOT ARB Ball Joint
    By howieallstars in forum Handling & Braking
    Last Post: 15th November 2010, 16:50
  3. Gearknob ball joint
    By george1987 in forum Vectra C / Signum Car Chat
    Last Post: 21st April 2010, 21:57
  4. bottom ball joint
    By paulvectrac in forum Suspension, Wheels & Brakes
    Last Post: 19th March 2010, 14:23
  5. Ball Joint failure
    By peter142 in forum Suspension, Wheels & Brakes
    Last Post: 27th March 2008, 18:18
