Thread: Gearknob ball joint
    Regular Member george1987's Avatar
    Nov 2009
    Plymouth/Southampton
    Default Gearknob ball joint
    Just got my astra vxr gearknob and it is identical to the standard one in my veccy. I am halfway through the swap, but I don't know how to get the ball out of its joint (connecting onto the shaft that goes into the gearbox). Looked in the haynes manual, but i'm not getting anywhere with it. Do any of you know how to seperate the ball and joint? Cheers, George
    Full Member Big Sig's Avatar
    Just looked on TIS and it says that it all comes off together when changing the gear stick.
    Can't find anything about seperating the ball and socket. Sorry mate
    argyll, scotland
    hold the joint if possible and twist the knob will just pop out just not alot of room in there, will be doing mine soon and have read the how2 on AON
    hope that helps
    Sunny Dartmoor
    Quote Originally Posted by george1987 View Post
    Use a screwdriver to prise it off..........
    Nov 2009
    All sorted now guys, thanks for the help.
  1. spinning ball joint
    By neill in forum Suspension, Wheels & Brakes
    Last Post: 7th August 2011, 21:09
  2. Ball joint issues
    By hothatch in forum Suspension, Wheels & Brakes
    Last Post: 19th February 2011, 21:46
  3. failed MOT ARB Ball Joint
    By howieallstars in forum Handling & Braking
    Last Post: 15th November 2010, 16:50
  4. bottom ball joint
    By paulvectrac in forum Suspension, Wheels & Brakes
    Last Post: 19th March 2010, 14:23
  5. Ball Joint failure
    By peter142 in forum Suspension, Wheels & Brakes
    Last Post: 27th March 2008, 18:18
