my cruise control on my vectra dont work at all ,its worked once since i got the car but once only i dont even get the green light on the dash when i try activating it any ideas pls
52 plate 1.8 petrol
model/ ellegence
52 plate 1.8 petrol
model/ ellegence
You can buy a spring for a fiver that goes under the clucth pedal that keeps the pedal at its highest point.
As the clutch gets used over time, the spring weakens or snaps and the pedal drops which makes the switch for the cruise not work correctly.
Takes less than 5 minutes to fit.
Don't forget you need to have pressed the preak pedal once on your trip before it will work too![]()
i have exactly the same car and have the same issue
The cause of this is a broken spring under the clutch pedal or which ever one it is. Its a known VX fault and there is a modified part which only takes a couple of minutes to fit and costs £6-7. Happened on my Vectra C 1.8 SRi when I had it.
were can i get part and what needs to be done??
One quick forum search:-
http://www.vectra-c.com/forum/showthread.php?t=33621
