Thread: Is CIM related to front parking sensors and/or blinkers?
    New Member procopy's Avatar
    Jul 2019
    Bulgaria
    Vehicle : Signum V6 Turbo
    Trim : Cosmo
    Engine : Z28NET
    Default Is CIM related to front parking sensors and/or blinkers?
    Gents, I have a weird issue that randomly swaps between ABS + ESP lights popping, front parking sensors and front right turn signal glitching. Usually happens in cold/wet weather. Upon full left turn, ABS + ESP would light up. Few minutes later, if car started again, they won't, but front parking sensor will randomly start beeping. If neither happens, front right turn signal will blink faster. In warm and dry weather none of this is present. While the CIM is the most probable reason behind ABS + ESP fault, does it also control turn signals and front parking sensors?
    Apr 2022
    romania
    8 Post(s)
    Vehicle : opel
    Trim : signum
    Engine : z20net
    Mileage : 120000 mi
    As far i know yes, CIM controls signal, parking and ESP
    Jul 2019
    Bulgaria
    Trim : Cosmo
    Engine : Z28NET
    Ah, great, thanks. That's somewhat good news, having to only deal with one module at a time
    Apr 2022
    romania
    8 Post(s)
    Vehicle : opel
    Trim : signum
    Engine : z20net
    Mileage : 120000 mi
    Before replacing it try cleaning everything that is cim related with alcohol and let it dry afterwards.
    https://youtu.be/GaLa6s_ASjY?si=IGVvEwvt9PZ0Ta5x
    Regular Member Jon1796's Avatar
    Sep 2015
    Norwich
    30 Post(s)
    Vehicle : Vectra VXR x2
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Mileage : 75,000
    Have you had car read for fault codes. If you say this happens when wet you’ll probably have to look for bad wiring arches, uec, front behind bumper.
    Oct 2022
    Slovakia
    Vehicle : VECTRA B and C
    Trim : GTS
    Engine : Z19DTH
    Cim have nothing to do with parking sensors. Parking sensors have their own separate unit what is back in car attached to Rec. Your issue could be corroded ground connection under the headlight.
  1. front parking sensors
    By Knight Rider in forum Electrical & ICE (including SatNav)
    Last Post: 13th October 2012, 14:21
  2. front parking sensors
    By woodze in forum Vectra C / Signum Car Chat
    Last Post: 13th May 2009, 22:35
