Page 1 of 4 123 ... LastLast
Results 1 to 10 of 38
Thread: front parking sensors
    Regular Member Knight Rider's Avatar
    Apr 2008
    Motherwell
    Vehicle : Vectra C SRi 1.8vvti
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    Default front parking sensors
    Aftermarket Front Parking Sensors now installed, I've fitted them a switch which is in the cup holder between the 2 front seats and when switched on it beeps. But, when I roll the car forward it's not beeping the distance to the object?? I've placed the sensors from A-D from Off side to Near side and into the correct A-D slots. Is there anything I've missed out? Activation is by pressing the brake pedal and this as I say gives a beep BUT no distance beep. Any info appreciated.
    TIA
    Scotty
    ps fronts are the same as the rear and they're beeping OK.
    Regular Member Neve'o's Avatar
    Norfolk
    Vehicle : Vectra SRi 150 Hatch
    Mileage : 69'000
    on the rear when selecting reverse the sensors have power all the time until taken out of reverse, how have you wired the fronts up to have a constant power feed? Im guess when press the brake the sensors get power until you release the brake again??
    Jul 2010
    This is London baby
    Vehicle : Dodge Journey
    Trim : SXT
    Engine : 2.0Tdi (VW Engine)
    Year : 2010
    Mileage : 53000
    Quote Originally Posted by Neve'o View Post
    Through a switch?
    Norfolk
    Mileage : 69'000
    through a switch wont make any difference if its wired off the brake light / pedal will it.
    Apr 2008
    Motherwell
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    I've earthed them to the nut under the battery tray then ran a cable from the red cable and extended it then ran it through the firewall into the glovebox to the cupholders between the front seats then onto a 2 sway switch then ran a cable from the switch along the passenger side through to the rear into the boot then hooked into the brake light wire.
    Norfolk
    Mileage : 69'000
    yeah so the sensors are only getting power when the brake pedal is pressed, sit in the car with brakes on and get some one to walk in front of sensors, they should work, lift your foot off the brake and they wont.
    As you have a switch in there you might as well wire the power off an ignition live that way if you happen to lift your foot of the brake, say while parking, the sensors will still be active until you turn the switch off.
    Apr 2008
    Motherwell
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    So I could hook it up to the ignition live under the gear stick ie black cable going to the ciggy lighter? would that be a 3 way switch then?
    1 - power
    2 - sensor unit
    3 - brake light
    Norfolk
    Mileage : 69'000
    To make it simple would be to forget the brake light, just have it on the switch, on and off when ever you need it then unless I'm missing another purpose for using the brake light?
    Apr 2008
    Motherwell
    Trim : Sri
    Engine : 18.vvti
    Mileage : 29,500
    So just run the 2 way switch as so. 1 wire from unit on the red cable,,,,,, 1 wire from switch to ignition live?
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Quote Originally Posted by BLACK KNIGHT View Post
    That should do it
  1. Anyone got front parking sensors.?
    By montyfert in forum Bodywork & Interior
    Last Post: 7th June 2012, 21:55
  2. Front Parking Sensors
    By war222 in forum Vectra C / Signum Car Chat
    Last Post: 11th December 2009, 13:33
