Thread: 1.8 VVT hesitant to rev after idling
    Jun 2020
    Ayrshire
    Trim : SRI XPII
    Engine : Z22YH
    Mileage : 100k
    Default 1.8 VVT hesitant to rev after idling
    Hi all, I bought a 57 plate Vectra SRI estate with the 1.8 VVT engine back in feb. 68k on the clock VX FSH. I love the car but I've noticed a slight intermittent issue.
    If I leave the car idling for more than a few minutes, like waiting at a drive through or car wash, when I then drive off the car starts hesitating to rev, and it struggles to get up to 70. It's still drivable but noticeably less powerful. If I turn off the engine, leave it a few seconds, and then start it up again that seems to solve the problem. I have recently changed the coil pack and plugs which I hoped would solve the problem, but it has happened since.
    Any help or advice would be greatly appreciated ☺️
    Oct 2013
    Derby
    340 Post(s)
    Trim : VXR
    Engine : Z28NEH
    Year : 07
    Have you looked in the engine section I’d think something like that might be in there?
    Teapot Tuned 255/300
    Tech2 & MDI diagnostics + SPS
    Apr 2016
    Ipswich
    93 Post(s)
    Trim : SXI limited edition
    Engine : 2.0 16v DTI
    Year : 2003
    Mileage : 140000
    My advise would be to wait until it happens than check the ecu for a dtc... don't turn the car off as it might wipe it as when you restart it goes back to normal... could be a simple intermittent short to ground on a sensor or a sensor slowly giving up, probably a cranksensor, or camsensor that is causing the problem but it could be something different like the throttle position sensor acting up, or the VVT mechanism getting stuck or the egr is sticky etc etc etc .. so again i advise you to have the ecu readout...
    Jun 2020
    Ayrshire
    Trim : SRI XPII
    Engine : Z22YH
    Mileage : 100k
    I found this one that seems similar. Not sure they solved it though ��
    Jun 2020
    Ayrshire
    Trim : SRI XPII
    Engine : Z22YH
    Mileage : 100k
    I have an ODB2 reader, so will try it out next time it happens. There weren't any codes last time I checked (I didn't know they could reset though), but I think the reader is pretty limited (NEXPEAK NX301). I guess I could bite the bullet and ask vauxhall to scan it.
    Regular Member petrolcan's Avatar
    Dec 2015
    Watford
    20 Post(s)
    Trim : Elegance
    Engine : 1.9 CDTI (120)
    Quote Originally Posted by _Tom_ View Post
    Or put a regional post up and see if someone can read the codes for you.
  1. Hesitant RPM in cold weather
    By bambal in forum Engine & Drivetrain
    Last Post: 27th January 2019, 22:40
  2. Vectra c hesitant
    By MARK RC in forum Engine & Drivetrain
    Last Post: 6th April 2015, 10:14
  3. Hesitant under acceleration
    By pistolpete in forum Engine & Drivetrain
    Last Post: 24th April 2014, 12:18
  4. Engine is 'hesitant'
    By bighammerfan in forum Engine & Drivetrain
    Last Post: 30th September 2010, 09:34
  5. Hesitant when cold
    By silent_bob in forum Engine & Drivetrain
    Last Post: 7th March 2009, 20:25
