Thread: Glove box trim broken :(
    ijk571
    Guest
    Default Glove box trim broken :(
    Does anyone know how easy it is to replace the thin plastic trim that holds the lower 2 screws of the glove box in place.?
    I undid the top 3 screws and where the lower 2 screwed into prompt broke (should have undone the lower ones first I know). I have tried to glue the broken bits together but it wont hold very well. I can just stick in a couple of self tapping screws if need be close to the holes. Is is possible without buying loats of dashboard?
    Regular Member andy.l's Avatar
    Wirral / ellesmere port
    13 Post(s)
    Vehicle : Astra j sports tourer
    Trim : elite
    Engine : 1.6 cdti
    Year : 2015
    the plastic trim is part of the glovebox,replacement glovebox im afraid
    Administrator plasma's Avatar
    Mar 2006
    On the Forum
    579 Post(s)
    Engine : 150
    Year : 05
    Mileage : 74000
    Hes talking about what they screw into which is part of the dashboard.. there isnt a lot you can do other that try to knock something up to refix them back with...
    May 2012
    North West (Warrington)
    240 Post(s)
    Vehicle : Vectra C 3.2 Elite Estate Auto Facelifted
    Trim : Elite with loads of "Extras"
    Engine : 3.2 Z32SE
    Mileage : 94,000
    I haven't needed to do it on my glovebox side, but I did break a similar section of the dash on the drivers side on my car
    In my case I found that a heavy duty cable tie did the job for me, but I only had one mounting point to concern myself with and not 2, also the trim cover under the light switch on the drivers side is much lighter than the glovebox, but worth a try fella and I suspect with a bit of "tweaking" you'll get it to work.
    Good luck in trying mate
    Dec 2010
    London
    8 Post(s)
    Trim : Premium SE
    Engine : 1.6 with 32KW motor
    I done the same thing
    To fix i rivetted metal banding to dash and now is stronger than before
    ijk571
    Guest
    I finally managed to fix it by screwing metal banding to each side of the two holes and pushing the yellow screw holders into that. Hopefully as good as before. It feels nice and secure.
  1. Broken banks of river = broken vectra...
    By andrew e in forum Vectra C / Signum Car Chat
    Last Post: 23rd May 2012, 20:48
  2. Glove box
    By tubby in forum Bodywork & Interior
    Last Post: 17th May 2011, 21:13
  3. Trim under glove box
    By Thunder in forum Bodywork & Interior
    Last Post: 6th October 2008, 19:41
  4. Glove Box
    By barney in forum Vectra C / Signum Car Chat
    Last Post: 8th November 2005, 00:05
vauxhall vectra glove box screws
