Thread: Trim under glove box
    Regular Member Thunder's Avatar
    Apr 2008
    North Yorkshire
    Vehicle : Vectra C Facelift
    Engine : CDTi 150
    Mileage : 71000
    Question Trim under glove box
    The Trim under glove box (flat panel)
    How is it fastened up, as mine just seams to hang down & rests on the carpet
    If i push it up i can see the heater vents pop though a couple of mm (but i cant see any way to keep it there)
    any ideas guys
    [Ex]Admin Duncan's Avatar
    It doesn't fasten to anything as such, but when you put the glovebox in you need to make sure it 'slides' correctly or it will hang down - although from what you describe it sounds like you've got it positioned correctly.
    Apr 2008
    North Yorkshire
    Engine : CDTi 150
    Mileage : 71000
    Cheers Duncan
    I'm just trying to find a rattle lol (i know its somewhere around there)
    & it just looks like it needs to be pushed up more, if you know what i mean
    Thanks again
    For a rattle in that area, have a look at the nut in this picture....
    I had a rattle yonks ago that was driving me nuts, I was convinced it was around/inside the HU area and even pulled it out to investigate. Eventually tracked it down to that nut being slightly loose, enough to rattle but not to fall off!
    Apr 2008
    North Yorkshire
    Engine : CDTi 150
    Mileage : 71000
    Cheers off to have a look
    Apr 2008
    North Yorkshire
    Engine : CDTi 150
    Mileage : 71000
    Got it both drivers & passangers side where lose
    I also took out the glove box & refitted it (lol you need three hands)
    it now seams to fit better & i know whats behind there now
    just need to road test her now & see if the rattles gone
    Cheers for the help Duncan & i owe you a
    Hopefully the road test will have no rattle and confirm it was those nuts! Took me ages to get to the bottom of it when I had it happen on mine!
    I may very well take you up on the when I'm up in the NE at Christmas.
    Apr 2008
    North Yorkshire
    Engine : CDTi 150
    Mileage : 71000
    Thumbs up
    No problem Duncan
    your more than welcome just drop me a PM
    i'll follow this up, just hope it works
    Did you do a road test?, or not yet?
    Apr 2008
    North Yorkshire
    Engine : CDTi 150
    Mileage : 71000
    lol no not yet
    Tomorrow if i get a chance,
    the wife wont let me drive just had a kidney stone blasted by the hospital so still under sedation after affects
    still got the vectra washed
  1. Glove box
    By Garfo in forum Styling
    Last Post: 30th June 2011, 23:02
  2. Glove box
    By tubby in forum Bodywork & Interior
    Last Post: 17th May 2011, 21:13
  3. glove box
    By rave5 in forum Bodywork & Interior
    Last Post: 31st January 2010, 18:47
  4. Glove Box
    By barney in forum Vectra C / Signum Car Chat
    Last Post: 8th November 2005, 00:05
