Results 1 to 7 of 7
Thread: Petrol Smell and Engine trouble :-(
    New Member greenlight's Avatar
    Nov 2012
    Warrington
    Vehicle : Vauxhall Vectra
    Trim : LS
    Engine : 1.8
    Mileage : 100,545
    Default Petrol Smell and Engine trouble :-(
    Hello all. I've read many posts regards to fuel or engine smells coming through the vents, but not for my model Vectra. So I thought I'd post a new thread to make sure I've got it covered. I've got a 2004 Vectra LS 1.8 Petrol and since last Friday I can smell what I think is petrol or something very similar coming through the vents. Now, if I don't turn the fan on or leave it on cold air, I can't smell it. It's only when the heat is turned up, it's really noticeable. It did this a while back, but somehow cleared itself up. Any ideas what it could be? Also, my Dad as got a Vectra 2005 Life 1.8 Petrol (Facelift Version) and when the car is started up in the morning, or after any cold start, the engine appears to be all over the place. The rev counter needle moves up and down and the engine doesn't idle, it's jumping everywhere. If you put your foot on the gas, it's got no power. Strangely, if you turn off the engine while this is happening and immediately start it again, it corrects itself. Regardless, once the engine is hot, the car regains full power and is like **** off a shovel. I just don't get it. Any ideas what the problem could be. Thanks in advance for your help. David.
    Regular Member viper8's Avatar
    Mar 2011
    Northamptonshire
    this is the same kind of problem i have got with my car .that your dad has with his .
    Mar 2011
    Northamptonshire
    Regular Member paz_badboy4life's Avatar
    Leicestershire
    Vehicle : Vectra SRi Dual Fuel NAV
    Trim : PreFace SRi
    Engine : 1.8 LPG
    Year : 53
    swap your MAF sensor with your dads. see if that makes a difference.
    Dec 2011
    Seaham
    Fumes smell could be a leaking exhaust flexi pipe??
    Do you get the EML with the rough running? If so, have the codes read.
    Erratic tick over can be caused by a few things, try cleaning the MAF and throttle bodies.
    Also check that the alternator is producing around 14 volts with the car running, the engine management will increase the revs to try and generate more power.
    Nov 2012
    Warrington
    Trim : LS
    Engine : 1.8
    Mileage : 100,545
    No EML with the rough running, but I'm going to try swapping the MAF sensor and Coil Pack over tomorrow on my Dads cars, see if that solves it. I'm assuming the parts are identical? With my car, I've found the source of the petrol fumes. The second injector from the left is soaking wet, while the others are bone dry. Does that mean the injector has to be replaced or can it be repaired and is it dangerous to drive in this condition? I've only had this car since November 7th last year, and I've already spend £500 ish since then on getting things fixed, the last being the Window wiper Linkage assembly had to be replaced as it fell to pieces. It's a good job the car is immaculate inside and out.
    Dec 2010
    Glasgow
    Vehicle : 1.9 Cdti Signum
    Engine : z19 DTH
    Mileage : 160000
    I had a similar thing - mines is a 1.9 diesel - could smell fumes when stuck in traffic. WHen i turned the fans off no smell , when i hit the button for recirculating the air - no fume smells. Had a good look under bonnet - couldnt see anything of the ordinary. Then i checked the cabin filter - it had fallen out of place (as i have a broken clip) - taped it up back in place and no smell. Don't know if this applies to your petrol but maybe worth a look just to see
  1. Signum starting trouble and smell of petrol!
    By iam2103 in forum Engine & Drivetrain
    Last Post: 9th May 2012, 18:32
  2. Petrol Smell
    By CDTi-SRi-Matt in forum Engine & Drivetrain
    Last Post: 5th February 2009, 21:20
  3. Petrol smell
    By cjm4378 in forum Engine & Drivetrain
    Last Post: 24th February 2008, 23:33
  4. petrol smell
    Last Post: 22nd November 2007, 19:40
  5. I can smell trouble ahead
    By plasma in forum Vectra C / Signum Car Chat
    Last Post: 29th July 2006, 17:27
