Thread: Petrol Smell
    Regular Member CDTi-SRi-Matt's Avatar
    Nottingham
    Default Petrol Smell
    I have the smell of petrol coming from my car and im not sure what it is?
    Ive never smelt it before up untill today, i know it cant be a leak because it only came on today and ive hardly drove anywere, not like ive caught it on anything.
    Is it maybe because the car is working harder in the snow and its burning off quicker? The MPG has dropped to 30.7 as well and before it was around 33ish.
    Sujestions?
    Matt
    Regular Member gromit's Avatar
    Cumbernauld
    Check the fuel filter. Don't know if the vectra is the same set up as the astra but my astras filter started to leak due to corrosion. Had to change it last week. Just a guess.
    Plymouth
    Id check for a leak anywayz.... it could be just sods law something has slipped or split or something
    Mileage : 000
    You might have caught the fuel filter on some frozen snow perhaps.
    Nottingham
    Cars going in for a service withing the next couple of weeks so will see what happens when they change the fuel filter
    Nottingham
    Oh and what have i got to look at when looking for leaks??
    Not very mechanically minded
    Cumbernauld
    The fuel filter is under the car approx twelve inches in front of the rear drivers side wheel and its just a can with a pipe going into both ends. if you put your hand on it and its wet just smell your hand to see if its petrol.
    My cars a GSi but im sure it will be in the same place for other models.
    Nottingham
    cheers pal, will have a look later or 2moz when its dryer
    Are they east to change if it needs doing?
    Quote Originally Posted by Vectracsri View Post
    No not if you read a few threads on here do a search & I'm sure something will pop up.
    Plymouth
    run ur nose around the car.... try and locate an area ish where the smell is strongest.
    I had a pug 405 with a dodgy connection into the injectors that leaked every so often..
    Just after a run in the car check the engine bay out and run ur hands all over the fuel pipes etc... if its wet smell to confirm!
  1. I Smell Petrol
    By Tam80 in forum Engine & Drivetrain
    Last Post: 4th June 2011, 12:54
  2. Smell of petrol in car
    By davidj387 in forum Engine & Drivetrain
    Last Post: 2nd July 2010, 07:46
  3. Petrol smell
    By cjm4378 in forum Engine & Drivetrain
    Last Post: 24th February 2008, 23:33
  4. petrol smell
    Last Post: 22nd November 2007, 19:40
  5. smell of petrol
    By kevinmcm19 in forum Vectra C / Signum Troubleshooting
    Last Post: 21st November 2007, 23:16
