Results 1 to 10 of 14
Thread: Tired Of Tyres !!!!!!
    Default Tired Of Tyres !!!!!!
    After Lots Of Looking Around I Think Ive Found The Best Deal For My New Tyres .
    Just Been Quoted £160 For Two Avon Zz3 Tyres In The Size Of
    225/45/17 Speed Rated Y Anyone Got Any Experiance Of These Tyres As I Havnt ????? Many Thanks In Advance :d :d
    Regular Member chrismiller's Avatar
    Hi just wondered why you would go for a 225/45 and not the standard 215/50 as this will affect ur speedo slightly ie 50 for a 17" and 45 if u are going for an 18" also i havent seen any real saving as some suggested by going wider...
    I put 225/45`s on and they were a good bit cheaper, also opens up the choice of tyres available...
    As Bainie Says 225/45s Are A More Readily Available Size At The Moment Its Only The Veccy That Uses 215/50s So Not That Many Brands About Cheapest 215/50/17 Tyres I Could Get Were About £120 Each !!
    have a look on ebay mate theres quite a few on there
    the 225's are also slightly lower profile then the 215's to,
    215/50= 107.5mm deep
    225/45=101.25mm deep
    about 1/4 of an inch in reality, so will look slightly sportier , and as said, the choice is a little better for the 225 size
    BB
    Quote Originally Posted by chrismiller
    the 215/50 has an overall diameter of 647mm. The 225/45 has 634mm. Thats 13mm difference over the whole diameter, 2.01%. Its recommended to stick with 2.5% difference in tyre size. If you can tell a difference in speedo with that then youre a better man then me
    Also, i dont know why vauxhall spec 225/45 18 tyres when they are 23mm bigger over the diameter than the standard 17. 225/40 is 10mm out which is a lot closer to the orginal tyre size.
    Quote Originally Posted by Andy
    this is tru, my size was only for the one side of the rim to the edge, lol
    BB
    Regular Member SAMMYBOY's Avatar
    Have You Tried Blackcircles On The Net....i Just Got 2 Dunlop Sport 225/40/18 For The Reasonable Price Of £210 Delivered Next Day...think Thats Quite Good...thats Cheaper Than My Work Can Get Them..and We Get Major Bodyshop Discounts On Parts...
    i got 4 part worn 225/40/18 michelin's with 5mm of tread for 200 fitted
  1. Looking Tired...
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 13th September 2011, 10:49
  2. Tired with bad MPG?
    By John LE in forum Comedy & Humour
    Last Post: 22nd December 2009, 22:00
  3. Tired Vec
    By SteveH in forum Vectra C / Signum Car Chat
    Last Post: 6th December 2009, 14:35
  4. I'm Tired
    By MJED in forum Comedy & Humour
    Last Post: 16th January 2006, 11:27
