Results 1 to 10 of 13
Thread: battery light and a demented dash, any suggestions?
    Regular Member TKD Colin's Avatar
    Jan 2008
    london
    Default battery light and a demented dash, any suggestions?
    OK, so about a week ago i started the car (2.0DTi) and the battery light on the dash stays on, so i give the go pedal a little blip, battery light goes out but traction control light comes on and stays on....
    couple of days after that i start the car battery light stays on for a while it goes out comes on again with the dreaded car and spanner light, they keep flicking on and off each time battery light comes on spanner light accompanies it, then i get the tractions control light come on and the fuel gauge dies.
    then today i start the car to come home from work traction control light comes on followed by the battery light it keeps coming on and off and every time the battery light comes on the speedo and rev counter die this continues for the first few minutes of my journey.
    any suggestions as to what could be causing this greatfully recieved.
    Ashington, Northumberland
    CIM module.
    Regular Member gromit's Avatar
    Cumbernauld
    My car is doing the same thing and I think its the cim module as it seems to be a common thing on the forum.
    Here, there and every where!
    Quote Originally Posted by GARY3306 View Post
    CIM module.
    Did the same on my veccy, new CIM and all was well again
    Nicking Ya Dinner.
    I'd start with a new aux drive belt 1st.
    Cumbernauld
    Quote Originally Posted by Caterman View Post
    Mine has the same problem. How much to fix and does it have to be a VX dealer?
    Jan 2008
    london
    thanks for the quick respones guys
    thought at first my alternator was on the way out, but when the dails started failing aswell i had to resign to the fact it could be the cim, was hoping that it wasnt though.
    OH well will check out the auxilary belts first and then take it from there.
    any ideas on how many of my hard earned £££'s will i be parting with for a new cim, just the part without labour.
    Thanks again,
    Colin
    Nicking Ya Dinner.
    Are your dash lights dim as well at night?
    Try a battery re-charge ovenight before you spend incase it's a not enough juice problem.
    [Ex]Admin Duncan's Avatar
    Quote Originally Posted by VauxVeteran View Post
    That won't explain all his symptoms - a dodgy CIM will though as the others have said.
    Jan 2008
    london
    dash lights arew still good and bright and aslong as my alternator is working ok battery charge should be good as she had a good 60 mile run out on the a3 yesterday. but will get the battery charge checked at the same time as auxilary belts.
  1. Replies: 4
    Last Post: 18th August 2012, 08:58
  2. Replies: 17
    Last Post: 16th August 2012, 10:07
  3. Battery Light ON - 14.1 volts at battery
    By snapsnap in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2011, 13:55
  4. Alternator/Battery Dash Warning Light
    By cavester in forum Vectra C / Signum Troubleshooting
    Last Post: 1st June 2011, 08:24
  5. HELP....battery light on dash?
    By hovis007 in forum Electrical & ICE (including SatNav)
    Last Post: 20th May 2009, 22:27
vectra c 2.0dti battery light and tc light problem
