Results 1 to 3 of 3
Thread: Vec c faults
    cumbria
    Default Vec c faults
    How do all, just bought a vec c but has a few problems
    first off is the wipers, just fitted a new mechanism, because that had gone, but some times the wipers wont work when you pull the stalk forward, even the screen wash doesnt work, only intermittantly tho, and when it does this if i push the stalk down and let go the wipers stop as soon as i let go???
    second is the heaters this only works on no4??
    And last fault is the springs klunking when i turn the wheel stationary?
    they havent snaped just dont seem to turn with the strut?
    Any info greatly appreciated.
    rothwell leeds
    Vehicle : vectra c
    Trim : sri
    Engine : 1800 vvt
    had sim problem on car that came into garage turned out to be bad earth feed to wiper motor causing wipers to park wherever....your 2nd problem.. heater motor resistor think theres a how 2 thread on the site not haard job just tight access...3rd problem.. jack car up remove wheel and grease the base plate where the spring sits do both sides then just let the grease work in....good luck fella
    cumbria
    Cheers fella
  1. ?Faults or not.
    By daddy5times in forum Electrical & ICE (including SatNav)
    Last Post: 12th February 2013, 13:46
  2. OP-COM faults
    By WoodleySaint in forum Vectra C / Signum Troubleshooting
    Last Post: 1st June 2012, 16:36
  3. faults
    By steelee in forum Tuning
    Last Post: 23rd November 2011, 00:46
  4. VEC FAULTS X2 Anybody help???
    By DonMafia in forum Introduce yourself.
    Last Post: 25th January 2009, 17:02
  5. Car Faults
    By GazVXLINE170 in forum Vectra C / Signum Car Chat
    Last Post: 22nd September 2007, 14:11
