Results 1 to 10 of 11
Thread: Gsi Clocks
    Regular Member VECTRA HEAD's Avatar
    Derry
    Default Gsi Clocks
    Guys i am thinking of putting Gsi/Sri clocks or similar(the ones with chrome rings) into my 02 2LTR DTI and i am wondering will they work ok,also would they be hard to fit?
    playing with spanners
    sure i have read in another thread that they plug straight in with no erorrs but when a problem occors it wont work properly in conjuction with the new clocks
    think thats right
    Regular Member Steven T Davies-Moss's Avatar
    shropshire
    I just put 2.2 Diesel clocks into a 1.8L petrol as i wanted the chrome rings... and bingo... jobs a goodun
    Derry
    Were they hard 2 fit?
    Regular Member Robbie69's Avatar
    they are a doddle, lower the steering wheel and pull out. Take off siler dash trim both sides of the wheel, Pull the trim at the bottom of the clocks. Two torx screws at the bottom of clocks, lower clocks and pull out remembering to undo the plug.
    Think there is a how2 on the site.
    Derry
    I think i`d rather get some-one else to do it,i think my nerves would be shattered trying to do this.
    It really is VERY easy mate BUT if you don't feel happy doing it then get somebody else to do it.
    Derry
    I probably wudn`t attempt it,do you think it is a worth while mod,considering that if a problem crops up it wont show up on the clocks.
    you could just change the fronts of the clocks! That will scare you though, look at the how2, it's on youtube too!
    cambs
    Quote Originally Posted by VECTRA HEAD View Post
    hi m8 you will loose some functions
    i lost the seat belt warning and next service light/due.
    very easy to fit m8
    pull of the strips over the light switch and the one above the glove box.
    pull steering wheel towards you and down as far as it will go.
    ease out the cover thats at the bottom of the clocks and pull towards you.
    undo the 2 torx screws at the bottom of the clocks.
    pull clocks out untill it free and face clocks down.
    undo the plug on back
    it has a black lever on it pull it down (you need to hold down a plastic lug that holds the lever in position first)
    remove clocks and replace.
    10mins at the most m8
  1. 140mph Clocks To 170mph Clocks
    By Lean6 in forum Electrical & ICE (including SatNav)
    Last Post: 27th September 2012, 20:48
  2. help clocks gone off
    By J100RSA in forum Electrical & ICE (including SatNav)
    Last Post: 9th November 2010, 12:12
  3. VXR Clocks
    By Aidi in forum Parts for sale
    Last Post: 16th September 2010, 07:11
  4. clocks
    By dar in forum Bodywork & Interior
    Last Post: 7th December 2009, 22:14
