Results 1 to 10 of 13
Thread: Climate control Help
    Regular Member SteveH's Avatar
    Apr 2006
    Wigan
    Default Climate control Help
    The centre button of my climate control facia is playing up , what i need know is , is the centre botton removable and does it work like the electric windows i.e with the contacts that often get dirty, it works in the rotary direction fine (fan speed 1-7) but when you depress it to select the menu .you have to all most push it through the dash
    Steve
    Jun 2007
    Black Country
    not 100% sure but i think its a microswitch that works when you push the button, drivers side heat control is the same on mine, adjusts heat no problem, but you need to push it like crazy to get both temps the same
    Apr 2006
    Wigan
    Sorted ... Going to collect a new unit on saturday
    Apr 2006
    Wigan
    Collected and fitted it now works perfecto, thanks Kev
    Regular Member poves's Avatar
    lancashire
    Your welcome mate - you know you always get first class service here mate - I even included fitting it for free !!
    P.S - thanks for the bits , It's a big help mate
    Apr 2006
    Wigan
    .... thanks for the chocy for the brats too mate
    Jun 2007
    Black Country
    how do you remove the unit, i want to check mine hasnt got a loose plug, as the lights sometimes take a while to illuminate, and heated screen sometimes switches itself off if i adjust the temp
    lancashire
    Pull the storage tray out , then get your fingers behind and it will pop out , the terminals are like a folding clip ( sort of see saw machanism ) be careful not to damage the connector clip .
    Jun 2007
    Black Country
    how does the storage tray pullout?
    lancashire
    Just pulls out , just wiggle it , they are a bit awkward .
  1. another climate control
    By Даниил in forum Electrical & ICE (including SatNav)
    Last Post: 10th December 2011, 19:43
  2. Climate control and GID
    By Ben_ in forum Electrical & ICE (including SatNav)
    Last Post: 5th October 2011, 19:30
  3. climate control
    Last Post: 10th August 2011, 09:34
  4. climate control
    By stu_c in forum Vectra C / Signum Car Chat
    Last Post: 13th December 2010, 18:27
  5. Climate Control
    By liphook in forum Electrical & ICE (including SatNav)
    Last Post: 15th December 2008, 04:10
