Originally Posted by
chrischrischris
I had a similar problem to what your describing.
I have exactly the same wheels. On mine I have the factory fit Bridgestone Potenzas.
When i noticed a slow puncture in one of my tyres, I took it to kwik fit to get it "repaired" when they took the tyre off the wheel they said it was simply unrepairable. There was a huge amount of very small rubber particles where the tyre had sheared itself apart because it had practically no air in it.
Because the tyres are ultra low profiles, they are steel lined, which gives them support, so you cannot tell when they are flat or not !!!
So because they tyres had gone flat but still looked normal, they had been shearing when driving along.
Basically the rule to be learnt is always check tyre prssure, espesh at near enuff £150 a tyre !!!
I would imagine u would have the same tyres if they are still the factory fit ones.
Hope this helps !
