Page 1 of 6 123 ... LastLast
Results 1 to 10 of 51
Thread: VXR / SRI Xp Owners. Jacking point ?
    Regular Member MrLOL's Avatar
    Wakefield, West Yorks
    Default VXR / SRI Xp Owners. Jacking point ?
    wheres the best place to put a trollery jack on the vec ?
    ive got a trolley jack and planning to lift up one corner at a time to clean the arches and alloys properly etc..
    Ive heard about people ending up jacking cars by the side skirts and cracking em, so i want to get it right.
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    if you look on the side sill/shirt you will see a upside triangle, and if you look a bit further umder the car you will soo a black square block, that will be the place to jack the car up
    May 2006
    scotland
    Quote Originally Posted by glynn View Post
    I think the bit on the sill is really designed for jacking with the supplied wind-up jack. For Trolley jacks, it is usually further under the vehicle. If you have the vehicle handbook, it will tell you. If you do not have a handbook, they can be downlaoded FOC from VX website.
    Belfast
    Yeah, like the Vauxhall manual tells you anything useful like that.
    As Glynn says, the triangular section just behind the arch is the place to jack on the front, rear has a similar section just infront of where the suspension arm meets the subframe. DON'T jack off the rear suspension, it's aluminium and will crumple like....er...aluminium.
    On a Sabbatical daviek's Avatar
    ayrshire scotland
    If its just a small harlfords type trolley jack it will be fine to use at the jacking points , its more the larger garage type jacks that cause problems
    Belfast
    No, don't use any trolley on the plastic jacking point.
    ayrshire scotland
    Quote Originally Posted by _ZS_ View Post
    Never had a problem with using a small trolley jack, wee bit of common sense needed ...thats all
    Belfast
    My common sense says don't jack a 1.5 tonne car on a small piece of black plastic designed to stop the OE jack moving sideways...
    ayrshire scotland
    Ok mate you dont use one and I do , what do you do when you get new tyres fitted in a tyre depot....bring out your own jack and tell them to use that.
    Regular Member stuee's Avatar
    witney near oxford ish
    i use a proper trolly jack on the jacking points never had a problem no funny noises! and there ent plastic aroun the jacking points! y would they put plastic aroun the jacking point to stop the standard jack from slipping? if a 1.5tonne car is slipping under the standard jack then plastic is hardly going to save the day!
  1. Definitive Jacking Point
    By Homer in forum Vectra C / Signum Car Chat
    Last Post: 20th November 2012, 23:00
  2. Jacking point surround
    By Ralphwells1967 in forum Vectra C / Signum Car Chat
    Last Post: 15th February 2011, 17:03
  3. Jacking point fell off.
    By rosssri in forum Vectra C / Signum Car Chat
    Last Post: 29th December 2010, 11:39
  4. help with jacking the car up
    By carlsondavid33 in forum Vectra C / Signum Car Chat
    Last Post: 21st November 2010, 10:18
  5. Friggin Jacking Point Fell Off !!!
    By Bainie in forum Vectra C / Signum Car Chat
    Last Post: 15th October 2005, 18:11
vectra xp owners
jackningxxxp
jacking signum from the front
vxr too low to jack
https:www.vectra-c.comforumshowthread.php66140-VXR-SRI-Xp-Owners-Jacking-point
