Results 1 to 10 of 24
Thread: Front Splitter Spray Painting !
    Regular Member Hynzy's Avatar
    Liverpool
    Default Front Splitter Spray Painting !
    Is it possible to spray paint a pre-primed splitter for the front of my car. If i buy the proper VX paint and laquer colour coded to my car.
    It seems an awful lot of money for what it is to spray such a small part for £70ish.
    Any help would be great
    Regular Member poves's Avatar
    lancashire
    I don't see why not ?
    Although I've not actually done it.
    Maybe someone else has , I'm sure someone else will advise on this .
    Maida Vale
    Easy to do, but using aerosols you'll probably get an "orange peel" effect, which you can only slightly remedy with cutting compound, but given where on the car the part is, it shouldn't really matter.
    space
    yer easy enough,give the splitter a nice key with with 1500 wet and dry useing warm soapy water,make sure you do right to the edges dry well so no trace of water is present,then panel wipe the splitter and start spraying from about a foot away dusting on the paint as you go,not to thick at first as you could get runs,when you have enough paint on leave to dry for about 4 to 5 hours in a warm room when dry flat with 1500 wet and dry in soapy water and mob and polish.hth
    Liverpool
    Thanks mate ! Just aslong as its the same colour and it will stay on for a good few years its all good !
    what exactly is an orange peel effect. You dont mean it will all flake off do you
    Thanks guys!
    space
    orange peel effect is what it says looks like the surface of an orange if that happens then you may as well start again because you will need to do a hell of a lot of flatting
    Liverpool
    Quote Originally Posted by don paul View Post
    Not quite sure about that bit. I understand that i need to prepare it first by giving it a rub with wet and dry so that the paint will adhere to the splitter.
    Apply the coats evenly and slowly build up the layers untill it is fully covered.
    Why would i want to rub it down with wet and dry again?
    What is 1500 wet and dry? is that just very fine wet and dry?
    What is mob and polish?
    Many thanks
    space
    when it is dry you flat it down again to get rid of any dust particals,you only rub it tillit feels smooth and has gone a bit dull.mop and polish is when you use compound ie g3 if you havent got a mop use a soft cloth with the use of plenty of elbow greace,once the dullness has gone wipe clean with a clean cloth and put a good coat of polish on.1500 is fine wet and dry.hth
    Liverpool
    Many thanks for that, i completely understand now.
    Dont i have to apply a laquer spray at the end ?
    space
    no if you get the spray from hallfords it will be all in the the can
  1. Spray painting front bumper
    By dti owner in forum Vectra C / Signum Car Chat
    Last Post: 4th February 2013, 13:18
  2. spray painting
    By DAVIDD88 in forum Vectra C / Signum Car Chat
    Last Post: 3rd March 2011, 00:21
  3. front splitter and plate holders painting
    By bertbuckie1 in forum Styling
    Last Post: 12th April 2009, 20:58
  4. Painting Irmscher Front splitter
    By Kyser143 in forum Vectra C / Signum Car Chat
    Last Post: 11th November 2007, 16:57
  5. Spray painting.
    By 2ltrT in forum Bodywork & Interior
    Last Post: 21st February 2006, 23:23
