Thread: 2.8T Vectra EML
    Tampere
    Default 2.8T Vectra EML
    Hi all and happy new year!
    I bought 2.8T V6 Vectra two weeks ago, was working really nice and then I ordered BSR stage1 remap, installed it and went for a testdrive.. itīs amazing till you push it real hard and fast, about 4000 or 5000 rpm's it loses power and limp mode goes on.. I checked the error codes and those are:
    P0007 fuel shutoff valve control circuit high
    C2908 (i didn't find any reason for that)
    I erased those codes and it's working fine again without eml light until pushed hard again. I tried also driving with normal map and there wasn't any problems.. hope you can help me, thanks guys.
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Email BSR for help. They are usually very good at support
    Jan 2006
    Norfolk
    Been wanting to do this on my 2.8T but have been put off by the number of reports that the ECU on the 2.8T is very temperamental, what sort of 2.8 is it a VXR or one of the Autos.
    Tampere
    I've send email to BSR.. thanks for advice! but i don't think it's remap what's causing this problem.. or is there some similar issues with others who has remap?
    Tampere
    Quote Originally Posted by bowler View Post
    I have Opel Vectra 2.8T V6 GTS Sport 230 bhp manual.. it's called like that here in Finland..
    Tyneside
    If it's only happening with the remap installed, they're obviously connected and going by the fault it's as if it may be struggling with the flow of fuel. BSR Should be able to help I'm sure as they do a lot of R&D before releasing something.
    Tampere
    I found reason for that other fault code..
    C2908 MAF Test Min Run Time
    so, is maf sensor faulty or can i do something for it (clean it, etc.)
    EVERYWHERE
    Quote Originally Posted by 2.8T_BSR View Post
    If the car works fine without the map then there is nothing wrong with the car.If you remap the car you may push things beyond their tolerances.If you've increased your emissions in any way or you are asking for something that 'your' engine cannot give then you will have problems.
    I say 'your' engine,because 'your' map may well work fine on another car with the same engine.
    EVERYWHERE
    Quote Originally Posted by mark1319 View Post
    Not as much as you might think.
    They (may) test it on one example of a car that the map is designed for.Meanwhile Vauxhall or whoever are also messing around with their sensors and ECUs.
    Tyneside
    That's where the problem is as they only use 1 maybe a few test cars and a lot of them have differences in the ECU which has been found when the PPC needs to read the ECU. The OP's map will need alterations made to it by BSR so everything runs smoothly.
  1. mods could i do to my vectra 1.9cdti vectra suggestion of cheap vxr bumpers
    By lynchy-- in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2013, 00:17
  2. Vectra b rose bush for vectra c rear upper control arm
    By supernova_abh in forum Suspension, Wheels & Brakes
    Last Post: 14th September 2012, 19:26
  3. Silver Vectra (Vectra C Sticker) Southport Ocean Plaza DU56
    By mishima in forum Spotted or put a flyer on a Vectra C/Signum or Insignia?
    Last Post: 29th September 2011, 23:25
  4. Replies: 9
    Last Post: 17th July 2009, 12:07
