Results 1 to 3 of 3
Thread: travel assistant
    Regular Member signumT's Avatar
    grimsby
    Question travel assistant
    anybody got one as i need a bit of advice mine works the fridge ok but the two cigar sockets on it dont power any thing tried phone charger and snooper but nothing.
    would it be a seperate fuse or not as the fridge works ok,if so were are all the fuses on a signum,
    [Ex]Admin Duncan's Avatar
    Yep, I got one. Waddya need to know exactly?
    Edit. Just reading your post again and you already asked the questions!!
    If your fridge is working then there is obviously power to the TA so the sockets 'should' work. I can only think it's one of two things...
    1. The centre pin on the plug of your two devices is not reaching the inside of the TA socket. I've had this on some devices in the past on sockets (not the TA sockets specifically). If they work in your front socket then 'may' rule out that reason.
    2. A fuse has gone. Do you not have an owners manual? That lists all the fuse boxes (3 of them!!) and the fuses in them.
      The TA has two fuses that relate to it. They are both in the fuse box that is inside the left hand compartment in the load area (boot).
      Fuse 19 is 10A and Fuse 26 is 25A
    Just been out to my car to do a little test. Removing Fuse 19 did nothing. TA still works so that fuse must be only for the Twin Audio feature of the TA (as it lists that next to Fuse 19 as well).
    Removed Fuse 25 and the whole TA went dead i.e. no fridge or sockets, so if your fridge is working it's not the fuse. Therefore I'd suggest that it may be my reason point 1 - the pins on the plug not reaching the inside of the socket?
    HTH
    grimsby
    Looked at all the fuses and tried six different plug in items ie phone charger gameboy charger snooper etc and still no power there but they all work from other two cigar sockets so now ill try a multimeter on the sockets unless someone else knows anything to look at as its a sealed unit as such so might be a trip to vxl
  1. travel assistant
    By chris in forum Vectra C / Signum Car Chat
    Last Post: 10th April 2008, 19:47
  2. Travel assistant ??
    By Syvlie in forum Vectra C / Signum Car Chat
    Last Post: 14th August 2007, 07:55
  3. Travel Assistant
    By Triple Trouble in forum Parts for sale
    Last Post: 11th July 2007, 08:23
  4. Travel Assistant or not ??
    By davyboy in forum Vectra C / Signum Car Chat
    Last Post: 3rd July 2007, 18:20
