Thread: Plumber needed?
    Regular Member blr123's Avatar
    Dundee, scotland
    Default Plumber needed?
    Hi guys,
    Any plumbers on the forum?
    Had a bit of a flood today and it looks like the motorised valve on the combi boiler has failed and allowed the central heating to be pressurised to/by mains pressure..........would that be possible.........it was certainly up at 5bar pressure and blew a fitting..........hence the flood ........any thoughts would be appreciated
    Bryan
    Wiltshire
    Are you talking about your central heating or your hot water going pop?
    The only combi I've ever owned only had a gauge on the heating side and that was fed/topped up by a hand valve from the mains water supply.
    Regular Member markspark's Avatar
    scarborough
    the central heating should be seperate to the mains water, and as simonali said it can only be turned on by hand!! check to make sure no little fingers have been messing with it!
    Regular Member 2ltrT's Avatar
    North-East (Middlesbrough)
    if the small heat exchanger broke down, it could let water, mains pressure direct into the central heating sysyem.
    Dundee, scotland
    Quote Originally Posted by simonali
    It was the central heating............and yes the CH is topped by opening the mains valve then closing.........there is a pressure gauge and just above it is the motorised valve...........I think this is where they can cross connect as there would not be any other explanation as to why there was 5bar pressure..........what do you think?
    Bryan
    North east HQ
    what type and make of boiler is it bryan, im a plumber/gas fitter, generally if the pressure in the heating system exceeds 3bar on the gauge, then the pressure relief valve will open and empty the pressure from the 15mm pipe that should be outside. if little fingers havent been playing then the only place where the waters can mix is in the hot water plate exchanger. theses are about £60 - £100 depending on boiler make
    if this has caused a flood inside then the PRV is incorrectly fitted or has become faulty as it should blow before 5bar
    Dundee, scotland
    It's a Worcester.....not sure of the model.......will get taht tomorrow.
    It was one of the radiator pipes that burst
    Bryan
    PS the relief valve has NOT been lifting
    I was tired this morning.... anyway ....
    Another thing to check, is that there is no blockage between the pressure vessel & the ch flow... it’s generally a flexible hose.
    If it’s blocked the pressure will slowly rise, when heating is on.
    Its probs a good idea to check the pressure of the vessel whilst you’re on... a standard bike pump will fit... the correct vessel pressure will be in manufactures instructions.
    If pressure is rising when heating is off is either the filler loop passing... or the heat exchanger has grown a hole.
    I’d recommend the PRV is replaced, approx £10. The filler loop should always be disconnected after filling.
    North east HQ
    i agree with mick that the prv should be changed if the pressure is above 3 bar, and its not blowing off.
  1. Is there a plumber/gas man here?
    By beat275 in forum General Chat
    Last Post: 27th January 2012, 14:01
  2. Anyone know a good reliable plumber?
    By wingz123 in forum General Chat
    Last Post: 22nd May 2011, 19:16
  3. Anyone a plumber ???????????
    By Signumcdti in forum General Chat
    Last Post: 26th April 2010, 21:49
  4. any plumber merchants out there
    By kevin hunter in forum General Chat
    Last Post: 10th December 2008, 16:00
  5. gas fitter/plumber in birmingham?
    By Nickzx6r in forum General Chat
    Last Post: 3rd May 2008, 14:29
