Thread: Diesel bleeding
    Regular Member craigbarlow18's Avatar
    Staffordshire (used to be Newark) And Back to Newark again!!
    Default Diesel bleeding
    Im looking at removing the inlet manifold and egr as one piece on my 2.2dti to clean them out as they at gunked up.. to do this i need to undo the 4 fuel lines into the head, WILL THIS NEED BLEEDING AFTER???
    Ive looked on TIS and it doesnt say to bleed system after but didnt want it to be a given.
    Hoping to do this tomorrow
    If you undo them then I would imagine you do - having read my haynes manual you apparently need a special kit to do it and it's a 4 spanner job. IE, you need 4 Vauxhall spanner monkeys to do it...
    Administrator plasma's Avatar
    On the Forum
    579 Post(s)
    Engine : 150
    Mileage : 74000
    Did the same on mine, stripped out the Upper and Lower manifolds.. 2 ways you can bleed it. Either let the fuel pump push the air through until it starts or turn it over with the fuel injector unions loose until diesel comes out then nip up the union one by one. Thats the option i opted for when i did mine.
    plasma, turning it over wont burn pump out will it, as far as i can see it wont be running dry, or am i wrong
    Regular Member andymagee1982's Avatar
    May 2008
    Widnes.
    Quote Originally Posted by plasma View Post
    I seen the spanner monky do this with my engine when the head was done. But he also used a hand bellow type pump for the inital pull through, Changed it over as fast as he could to the filter then started to turn it over. When it never went he opend the union bolts a bit till he seen the fuel leaking out. A few more seconds turning and it fired up. But i must say well worth doing if you know how the pick up after that was amazing.
    On the Forum
    579 Post(s)
    Engine : 150
    Mileage : 74000
    Quote Originally Posted by craigbarlow18 View Post
    The diesel should more of less be there right away. Its only if it drains right back to the tank then you should really use the pump to suck it all the way back up. As long as the fuel filter is fully topped up you should be ok.
    East Midlands
    Quote Originally Posted by andymagee1982 View Post
    ?Is this the type of thing you mean..
    http://www.screwfix.com/prods/77865/...l-Priming-Tool
    May 2008
    Widnes.
    Quote Originally Posted by macdad View Post
    It is mate the pipe just about fitted into the filter holes. Its tricky to take it off fast and replace the filter pipes.
    I suppose you can fit it anwhere on the fuel line i.e the leak off's, Its got to be easer swapping it over on them?
    New Member dicthebig's Avatar
    Aug 2009
    Bulgaria,Italy
    Vehicle : Vectra C Y20DTH
    Engine : Y20DTH
    Year : 2002
    Mileage : 167000
    can some one put the pic of right place for pump? It is often need of bleeding diesels.
    Regards from sunny Bulgaria!
    Bristol
    2.0 and 2.2 dti need to be bleed. if you turn the car over on the starter to bleed air give the starter a rest after a few turns or you will cook the starter and its not cheap. I have even known a garage to burn out the starter. You can buy speacial bleeders on ebay or some good acc shops .
  1. Bleeding the air from the diesel fuel system
    By pete7175 in forum Engine & Drivetrain
    Last Post: 27th July 2016, 07:24
  2. bleeding bleeding and adjustment
    By noudder72 in forum Suspension, Wheels & Brakes
    Last Post: 26th December 2011, 11:29
  3. Need Info on Bleeding diesel pump
    By Pjuk in forum Engine & Drivetrain
    Last Post: 26th February 2011, 17:16
  4. Diesel bleeding
    By dti111 in forum Engine & Drivetrain
    Last Post: 6th February 2011, 17:08
  5. Bleeding diesel engine
    By bigbenny4gf in forum Vectra C / Signum Troubleshooting
    Last Post: 17th September 2009, 07:53
