Results 1 to 10 of 11
Thread: Computer help needed...........please
    Regular Member silverhairedracer's Avatar
    ESSEX
    Default Computer help needed...........please
    My missus bought an external hard drive for my xmas prezzy,
    It runs on the 2.0 usb,
    When connected it shows as drive G,but that is as far as goes when I try to open it up all I get is..........
    G:\ Not Accessable The file or directory is corrupted and un-readable
    Any ideas ? I use windows XP, The Hard Drive is a Maxtor Basics 500GB external Desktop
    edited :
    I've now found documenation
    Main complaint people have about this model is that when hot it will not connect via USB
    What specification is the computer you are connecting to?
    Is it operating on 32 or 64 bit?
    PC
    Pentium III, 500Mhz equivalent processor
    or higher
    • Windows Vista, 2000 Professional, XP Professional,
    or HP Home Edition
    • 128MB RAM or more as required by operating system
    (256MB recommended)
    Try this page :
    http://www.seagate.com/ww/v/index.js...00f5ee0a0aRCRD
    Wolverhampton
    right click, format, choose ntfs as file system. tick quick format then start.
    that should sort it out
    Garthorpe
    Quote Originally Posted by vxrmartyn View Post
    what he said
    Regular Member 67688c's Avatar
    Apr 2008
    In UK
    Very strange..
    I assume the drive is showing up in XP, in which case you could try re-formatting it. Other possibility is that your USB port is not supplying sufficient power, does it have the option for a external power supply.?
    It may of course have been returned by someone to the store, prior to your wife buying it, in which case, if no joy I would return it.
    edit: went to edit, then waited, and waited!
    Looks like you need to format it before use
    Right click on the G drive then format
    After the first format you might end up only seeing about 50MB of capacity
    If this happens, then perform another format
    You then might end up seeing 100MB of capacity
    Repeat the process until you see the full 500MB of capacity
    Looks like people are also reportign issues with this device and SP3
    ESSEX
    You are diamond fella !!,sorted thanks to all.
    Nicking Ya Dinner.
    Quote Originally Posted by silverhairedracer View Post
    Is this the reason you don't have a Tom Tom?
    ESSEX
    Quote Originally Posted by VauxVeteran View Post
    I have the smaller version its called a TIM TIM
    Nicking Ya Dinner.
    Whatever you do, don't move into clean instal Sata drives, you'll be there a month of sundays trying to figure it out.
    I'm suprised windows didn't just ask you if you wanted to format the drive
  1. Computer help needed
    By neill in forum General Chat
    Last Post: 1st August 2012, 19:39
  2. Computer Help Needed..
    By macdad in forum General Chat
    Last Post: 15th November 2009, 21:39
  3. computer help needed please...
    By ditchp in forum General Chat
    Last Post: 21st June 2009, 21:24
  4. Computer help needed
    By Ste in forum The 'Off Topic' room
    Last Post: 21st May 2008, 10:59
  5. computer help needed
    By vectra 2.0 t in forum General Chat
    Last Post: 27th January 2006, 20:17
