Thread: Slipping clutch
    Chelmsford
    Default Slipping clutch
    The clutch has started slipping on my 2004 1.8 veccy, although it's only done 52k... Seems a bit too soon to me, any thoughts anyone?
    I was supposed to get it checked by the stealers about 8 months ago, because of the classic 1.8 clutch judder problem (when cold only), but didn't as they said they'd charge me for the strip and rebuild if it turned out that it wasn't a manufacturing fault. I couldn't risk ending up with a big bill...
    Anyone know roughly how much a new clutch will be inc fitting? I'm prepared for bad news...
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    i had a quote from vauxhall for a clutch replacement. there were 2 prices, not sure what the difference was.
    £600 or around £700
    clutchright.co.uk quoted me £350
    mr clutch quoted £403
    Dial a Clutch quoted £235
    all quotes inc VAT, parts and labour
    let me know how u get on.
    Jun 2007
    Black Country
    Quote Originally Posted by carl bear View Post
    £600 or around £700
    A few mates i know have used Dial a clutch and all seem really happy with there work,
    Mr clutch i wouldnt touch with a barge pole
    Full Member Big Sig's Avatar
    52k for a clutch? too soon? depends on how its driven i.e. if its held on the clutch a lot or not.
    Chelmsford
    I've had the car since 29k and most of the miles (probably 75%) are motorway, so I'm very surprised that it's going...
    I don't have a habit of holding the car on the clutch at all, however, I've never been completley happy with the position of the pedal (see various other moan threads started by me!) as it seems to travel a very long way, so maybe I've been letting it slip sometimes without realising...
    If I can get Dial a Clutch to do it for £235 then I'm gonna definitely use them! That sounds like a bargain.
    Thanks for the advice!
    If you have done most of the milage it does sound a bit soon, but you never know how it was treated before Good luck with the new clutch
  1. New Clutch Slipping
    By Anth92 in forum Vectra C / Signum Car Chat
    Last Post: 5th December 2012, 02:56
  2. Clutch slipping and loosing clutch/brake fluid
    By marty_b0y in forum Engine & Drivetrain
    Last Post: 31st May 2012, 00:18
  3. Slipping Clutch
    By kel123 in forum Engine & Drivetrain
    Last Post: 12th July 2008, 11:16
  4. clutch slipping
    By carl bear in forum Engine & Drivetrain
    Last Post: 10th May 2007, 14:08
  5. clutch slipping?
    By tonyblade in forum Engine & Drivetrain
    Last Post: 20th February 2007, 19:54
