Thread: Abs Sensor
    Regular Member mad4stela's Avatar
    Newtownabbey
    confused Abs Sensor
    Hi There. I was just wondering if i am able to buy the rear abs sensor for my veccy or do i have to buy the whole bearing hub. Abs light is on and showing on diagnostic as sensor. I do think there is a bit of a humming noise coming from the same wheel. I was convinced i needed a new bearing, but after reading a few post on the forum i'm not so convinced it's the bearing. Any help/advice would be very much appreciated.
    Thanks all and merry chrimbo to all
    I'm pretty sure the ABS sensor is part of the hub. Gimme a sec....
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    I'm sure your spot on D. My new front hub/bearing came with the ABS sensor built in. It looked part of the unit. That was front though.
    Newtownabbey
    Thanks. Yeah thats what i thought cause i've already got the bearing and i can't see no easy way to remove or install the sensor. Just me trying to save a few shillings at this time of year.
    Can anyone also tell me if the bearing can be done DIY or is there specialist tools required.
    Thanks again
  1. Replies: 3
    Last Post: 13th August 2012, 22:25
  2. P0141-04 o2 sensor heater circuit open (bank 1 sensor 2)
    By Mark1892 in forum Engine & Drivetrain
    Last Post: 3rd August 2012, 09:19
  3. Fitting & Installation of ABS Harness & brake Help sensor sensor
    By Elahi_786 in forum Suspension, Wheels & Brakes
    Last Post: 17th April 2012, 20:46
