Thread: misted windows
    May 2007
    south ockendon
    Default misted windows
    now the weather has gotten colder, nearly everytime i get in the car in the morning the front and rear screens have condensation on the inside
    the rear is not too bad as the heated rear window clears that in a couple of minutes but the front is a proper pain in the @rse
    on very cold days the front even has a thin layer of ice on it
    has anyone got any idea why this happens? or more importantly how i can stop it
    i have tried shutting all the vents and it still happens, is it another vectra design flaw?
    Regular Member WHOOSH05's Avatar
    On the back wheel
    pollen filter?
    Belfast
    Clogged up pollen filter, or blocked drains in the scuttle.
    May 2007
    south ockendon
    its got a new filter in already, will check the drain holes tomorrow, cheers guys
    Belfast
    If that doesn't do it, the car just may have a buildup of moisture that isn't clearing with the cold weather, to clear the buildup leave the car running with the heater on full and the aircon on recycle for 30 mins after you return from a journey. That should heat up and remove the moisture.
    Also clear out any stuff you have in the car that could be holding moisture - old coats, rolls of kitchen paper or things like that.
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    I mainly do short journeys, 3 odd miles or less and I get a build up of moisture in the car that doesn't get a chance to dry out. You really notice it in this weather as like you say the windows mist up.
    Try running with your A/C (hot is fine) on permanantly for a week, see if that sorts it. HTH
    Regular Member MalcGSI's Avatar
    E Sussex & Kent
    Check the spare wheel well for water.
    Regular Member Atomic's Avatar
    Southampton
    I had this problem, i looked and tried almost every thing with no joy. one day i got the wife to clean the inside of the car and she found one of the rear window slightly open so she done it up and no more mist on windows!!!!!
    Mileage : 000
    It must be a bit of a phenomenon with the weather or the Vectra, as I don,t turn off the air con on mine and mine mists up sometimes, never had it freeze on the inside though. When the servo for the air "recirc" flap broke a tooth off. I sussed that the servo/"recirc" flap works in the back ground (so to speak) in othere words when you switch off the engine the "recirc" flap closes. Thus keeping the heat in the cabin of the car for longer. It is a bit annoying to have to wait for the condensation to clear from the windscreen though.
  1. misted up headlight
    By baz2003uk in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2012, 22:03
  2. Misted windows - found the problem!
    By andreitone in forum Bodywork & Interior
    Last Post: 14th December 2010, 15:17
  3. Misted Lights
    Last Post: 30th November 2009, 22:20
  4. headlight misted up
    By VECTRA HEAD in forum Electrical & ICE (including SatNav)
    Last Post: 21st July 2009, 15:01
  5. Fog light misted up!
    By bertxuk in forum Bodywork & Interior
    Last Post: 10th December 2007, 12:04
