Thread: oil filter and oil change - 3.2v6
    Regular Member effone's Avatar
    Bedfordshire
    Default oil filter and oil change - 3.2v6
    Hi guys,
    Couple of questions -
    Am i correct in saying the 3.2 needs 4.75 litres of oil?
    Also, where does the filter live, i've seen that it is the 'cartridge' type. Also there's a large rubber gasket that comes with the filter - is this for the housing that the filter clips into?
    Sorry for the daft questions...
    Cheers,
    Ian B
    Mileage : 000
    Sounds about the right amount of oil. But check the dipstick when you have finished just to make sure.
    As to the oil filter is situated on the front of the engine by the exhaust, be care full when undoing the filter as the exhaust might be hot. You will need a 23m/m socket to undo the oil filter housing.
    Bedfordshire
    Quote Originally Posted by ed taylor View Post
    cool, cheers...
    any advice on the gasket?
    thanks,
    ian
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Quote Originally Posted by effone View Post
    cool, cheers...
    thanks,
    ian
    Gasket (aka big o-ring) should come with a new filter. It does if you go to VX stealer.
    Bedfordshire
    Quote Originally Posted by gtr1000 View Post
    got ya...
    just taken a look... is the oil filter housing just above the lambda on the manifold...??
    the one on my missus's 2.2 astra is on top of the engine... hence the (possibly) daft question...
    cheers,
    ian b
    Regular Member poves's Avatar
    lancashire
    You will see it pointing horizontally towards your radiator , black plastic moulding .
    Mileage : 000
    Quote Originally Posted by poves View Post
    They must have changed them, as mine is an alloy filter holder.
    Bedfordshire
    that's the joker...
    i'm going to change the oil etc on friday (if i get a day off!!) and i'll post back what the housing is made of then...
    thanks again for everyone's help
    ian b
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Same here, on a 52 plate 3.2
    EDIT - just to add that no matter how well you drain the oil from the sump. be prepared for some (actually a fair bit) to be in the filter housing when you unscrew it. Lots of rags recommended around the filter housing.
  1. Air Box mod & Filter Change
    By themarbleman in forum Engine & Drivetrain
    Last Post: 19th February 2011, 16:37
  2. Oil/filter change
    By Dobs in forum Engine & Drivetrain
    Last Post: 17th January 2011, 00:02
  3. NTS.Oil and filter change.
    By felixx in forum Engine & Drivetrain
    Last Post: 24th July 2010, 19:53
  4. Oil and oil filter change
    By spida_singh in forum Insignia car chat
    Last Post: 24th March 2010, 08:28
  5. How 2: Oil and Filter change 3.2
    By killer_bunny in forum Vectra C / Signum Car Chat
    Last Post: 5th March 2010, 02:29
https:www.vectra-c.comforumshowthread.php63870-oil-filter-and-oil-change-3-2v6
vauxhall insignia 3.2 oil capacity
change oil filter vectra c v6 3.2
