Results 1 to 10 of 11
Thread: Help with Fuses!
    Edinburgh
    Default Help with Fuses!
    Hi folks
    Having a spot of trouble with my Vectra SRI 2.2 Petrol 05
    Washer Jets stopped working so was told by Vauxhall to check the fuse (10A). I unfortunately don't have a manual for the car so checked all the 10A fuses and all were ok.
    Problem is now the engine management and traction control warning lights are now on and the screen says 'brake switch problem'
    I am sure fuses are all back correct but need a list of the position numbers to confirm
    I'm concerned I've managed to do some damage here...anybody got any ideas??
    Regular Member carpet's Avatar
    Jul 2006
    TENTERDEN KENT
    According to my W/D there are two fuses in the wash/wipe system. Both are located in the engine fuse box, F5 is 15amp and F22 is 30amp. All the 10amp seem to be controlling parts of the lighting circuit, a/c or ECU. This info is for 2002-05/Sept 2005-55reg. Hope this info is of some help.
    Edinburgh
    Looks like I may have replaced a fuse wrongly that controls the ecu!
    Any chance you've got the position numbers for all the fuses in the engine box?
    Regular Member willc01's Avatar
    UK Motorway Network + some smaller roads
    If you go to the Reference Library here you can download all the manuals from Vx after registering
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Hi mate, me again from over on Z22se, will have a poke around and see if I can find a list.
    Regular Member 900ss's Avatar
    May 2008
    Bucks
    Quote Originally Posted by SRIstu View Post
    Is it not printed on the inside of the fuse box lid?
    Mine is
    Edinburgh
    Hi mate...cheers much appreciated, trying to get it sorted for tomorrow...45 mile run to work!
    11 Post(s)
    Quote Originally Posted by willc01 View Post
    No longer need to register.
    http://www.vauxhall.co.uk/vaux/pages...uals/index.jsp
    Edinburgh
    Quote Originally Posted by 900ss View Post
    Mine is
    It's just got the numbers unfortunately.
    Got the info from the vauxhall website...well the 2007 manual but seems to be the same. All fuses correct so gonna try disconnecting the Battery for a bit.
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Disconnect for at least 20 mins, have your dials ever dropped in the past?
  1. Fuses
    By roverjay in forum Electrical & ICE (including SatNav)
    Last Post: 16th March 2012, 00:50
  2. 12V fuses
    By BigWilko in forum Electrical & ICE (including SatNav)
    Last Post: 27th July 2010, 20:57
  3. What are all the fuses used for?
    By TheWildHaggis in forum Vectra C / Signum Car Chat
    Last Post: 7th May 2008, 18:44
  4. Fuses
    By mickontherun in forum Vectra C / Signum Car Chat
    Last Post: 18th October 2007, 17:06
  5. fuses
    By topbuzz in forum Electrical & ICE (including SatNav)
    Last Post: 24th March 2007, 22:35
