Results 1 to 10 of 19
Thread: 3.2 GSI Thrust/Clutch bearing Question.
    Lincoln
    Default 3.2 GSI Thrust/Clutch bearing Question.
    Hi Folks,
    Just started to notice a slight 'whining' in 1st gear (only). Today I can clearly hear what I think is the clutch release/thrust bearing. Its a 'low' spinning noise that goes away when I press the clutch.
    Does anyone know if this is purely down to the thrust bearing or could it also be a potential gearbox problem (gulp!)? If I get the thrust bearing changed, should I change the clutch at the same time (due to the job being really difficult)? Any ideas of costs ???
    Frightened !!!
    Many Thanks.
    East Midlands
    Could be worn input shaft splines on first gear..?Does it engage gears without crunching with the other gears.
    Lincoln
    Default Thrust Bearing/Clutch WarrantyWise
    Hi, thanks for replying, I can engage al of the gears very easily, there are no noises, its just that I can hear a 'slight whinning' noise whilst driving in first gear. Pretty sure the thrust bearing is worn tho (It's just happened whilst I have left the car outside a hotel for 3 days in the cold).
    If it is the thrust bearing, should I replace the clutch at the same time
    (if the job is really difficult) ? Do you think the g/box will need to be looked at ?
    I have a warranty with WarrantyWise so will try these fella's out, not holding my breath !
    Anyone had any joy with WarrantyWise ?
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    If the noise goes away when you press the clutch, then it is unlikely to be the release bearing, as the release bearing is stationary until you press the clutch pedal and bring it into contact with the clutch release.
    Sounds like input / lay shaft bearing on the gearbox to me.
    East Midlands
    Quote Originally Posted by Ste View Post
    A worn thrust or release bearing becomes noisy when the pedal is depressed,and you say the whinning is heard when first gear is selected.
    A few questions..
    ?Does the noise disappear after the engine has warmwd up to full temp.
    ?Have you noticed any oil leaks anywhere under the car around the gearbox area.
    Sounds like the ist gear lay shaft splines to me as stated earlier.
    Lincoln
    Had the car looked at, mechanic has confirmed it is the thrust bearing. He said it's not that bad (agree as it has just started making the noise). The whinning in 1st is very hard to hear, he has suggested leaving it for a while so we can state that its definately the gearbox, then it's strip-down time. WIll have to replace clutch at same time (as its very difficult to get at), a new fly wheel quoted from the Stealers is £900 !!!!
    Watch this space.
    Lincoln
    Gearbox is out & stripped, garage is saying main g/box diff is knackered and 1 layshaft bearing, they are looking at the rest and will call me when
    they have looked at everything - Glad I have a warranty !!!!!
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I thank you.
    East Midlands
    I thank you.
    ste sounds like you and i were right on this one
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Certainly does.
  1. Worn Thrust Bearing?
    By LeeU in forum Y & Z30DT Specific
    Last Post: 9th August 2012, 09:24
  2. Clutch Thrust Release Bearing Perhaps.?
    By sootyville in forum Engine & Drivetrain
    Last Post: 24th July 2011, 07:58
  3. Thrust Bearing 1.9cdti 120
    By stevie16v in forum Engine & Drivetrain
    Last Post: 11th May 2011, 18:08
  4. Thrust bearing noise
    By robengland9 in forum Engine & Drivetrain
    Last Post: 21st February 2011, 13:48
  5. DMF or Thrust bearing
    By skidmark1 in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2011, 20:52
vectra c gsi clutch bearing
