Anyone know what the wear limit is for the rear discs (3.0CDti Estate) before they need replacing?
Micrometer at the ready![]()
If you can feel a lip, they probably need doing...
now come on a small lip is acceptable![]()
Personally i would change them with every 2nd set of brake pads as they do seem to wear rather quickly or if you dont know how many sets of pads it has had when the lip gets to about 3mm MAX !!!!!
^^^^ Just what the drinkmeister said.....
Thanks everyone from comments. I take it that there is no scientific solution like measuring thickness at several points around the disc then?
there is a wear limit measured with a vernier caliper and this limit is stated in the haynes manual i just aint got one any more![]()
keep in mind that a venier only measures the highspots on the discs.....
That, and that a disc and pad kit from VX is little more than a set of VX pads...it just makes too much sense..so change them if in any doubt
Nothing wrong with that. I measure the ones on my S2000 with a micrometer every 6 monthsFortunately I have a copy of the service manual for the Honda which tells you how to check them so was hoping for the same for Vx
Can't use a vernier as that would measure the lip and not the disc. Need to use a micrometer. Now that's being a realthere is a wear limit measured with a vernier caliper
Phil
