Thread: help with bros astra
    Regular Member howey's Avatar
    Oct 2006
    tyne and wear
    Default help with bros astra
    ok heres the gist of it....battery dead , bought new battery , lasted 2 days , dead again , power steering also went. it hasnt been started for 4 days went to have a look this morning started no bother , let it run for 10 mins switched it off , tried to start it again and it was as if battery was dying, slowly turning over but wouldnt start? had a new alternator about 1 1/2 yrs ago its a 02 astra dti , checked alternator belts and all seemed ok , any ideas anybody?
    Oct 2006
    tyne and wear
    nobody got a clue then????
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Was the battery fully charged before you fitted it?
    Think i would get the alternator checked if the battery was charged before fitting.
    Are you certain the battery is at fault here, it could be a problem with loose or dirty connections at the starter or earth connections on the engine/chassis or might even be the starter itself. The power steering takes its supply directly from the alternator so only works when the engine is running. If you had no power steering when the engine was running its likely you have a faulty alternator
    i'd check the charging voltage when running ( should be between 12.8 and 14V ) to confirm the alternator is running okay...if it's making voltage, then it's fine..
    it could be a direct short to earth ( faulty diode pack in alternator) or the like that is dischargeing the battery..Also, do a drop test on the battery with the multimeter..it shouldn't dip below 10.5V when trying to start it...and static cold, the battery should have 12.3-12.5V in it.. any less indicates either a bad cell in the battery or a slow overnight discharge..
  1. Is it Astra h or Astra j gearstick that fits vec c
    By jon1.9cdti in forum Bodywork & Interior
    Last Post: 10th May 2012, 07:28
  2. These are Astra but,,,,,,
    By Derek Mc in forum Vectra C / Signum Car Chat
    Last Post: 15th October 2010, 19:30
  3. Replies: 10
    Last Post: 17th February 2010, 13:20
  4. Astra 1.6 SXi 5dr
    By Braggy in forum Cars for sale
    Last Post: 19th July 2006, 20:37
  5. 5th Gear - 888 Astra vs Astra VXR
    By VectraV6CDTi in forum Vectra C / Signum Car Chat
    Last Post: 1st July 2006, 00:26
